Old 24-12-2013, 01:36 PM   #1
kcej
2mny projects 2 lttl time
Default AU1 Where are gas fuses or relays?
I just bought a 9.98 Fairmont on dual fuel.
I filled the LPG, but it won't start or run on gas, but then there is no power to the solenoids, except when I hotwire them (I have only found two, not three )
I'm thinking there are fuses blown, but I cannot find any to check. I guess it could also be a faulty relay.
Can someone please give me info on where to look for them and what they look like.
Thanks Keith
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2013, 02:08 PM   #2
Kil4Collingwood
Kil4Collingwood's Avatar
Aftermarket installations can be a pain to troubleshoot, everything depends on how good the install was you'll have to jyst keep searching I guess.
The way lpg prices are going unless it's a cheap and easy fix you'd have to wonder if it's worth it though.
Sent from my GT-I9300T using Tapatalk 2
Kil4Collingwood is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2013, 06:59 PM   #3
kcej
Default Re: AU1 Where are gas fuses or relays?
Found and fixed
Actually found FIVE separate coils or solenoids---NO fuses
The culprit was the big blue coil that sits on the converter itself (BRC AT90E)
It was open circuit - just dead - so I replaced it with a new one and
BINGO - Car idles and runs VERY nicely on gas too. The rest of the system is obviously working as it should.
Thanks anyway guys.
