Old 30-08-2013, 06:59 PM   #1
ben131185
Default changing control arm bushes and ball joints
i have been chasing a suspension noise in the front.
considering replacing the upper and lower control arm bushes and upper and lower ball joints.
as i'm soon to do my brakes maybe it will be a good time to do it all together.
i don't have a press to do the bushes, can i get by with a g clamp/vice to remove the old and fit the new?
i'm thinking i can just use a ball joint separator for the ball joints.
has anyone done this at home successfully without a press?
ben131185 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2013, 07:59 PM   #2
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Default Re: changing control arm bushes and ball joints
I did the upper arm bushes with a vice, but used a press for everything else. I don't see why you couldn't use a vice, however it will need a fairly big opening to allow for the bush, spacer and control arm to fit in there. For the price of a large vice, you would be better off buying a press.
The ball joints will need a 50mm spacer tube to press them in.
For the lower control arm, I used a 85mm tube spacer for the front bush and a 75mm for the rear bush.
To get the bushes out of the lower control arm I just put a scissor jack in between the bushes and pushed them out.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2013, 07:51 AM   #3
peterljohnson55
peterljohnson55's Avatar
Have you considered your sway bar D bushes as well?
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2013, 10:01 AM   #4
ben131185
i did the d bushes about a month ago.
