14-03-2011, 03:46 PM | #1 | ||
Ive got the tickford sunroof on my AU2 XR8 and ive noticed that the sunroof glass seems to rattle over bad bumps when closed..Not a problem when open.. In the closed postion ive got slight up and down movement when pushing the glass from the inside with my hand..Thought id ask in here before attempting to adjust the glass slides myself.
Is the job too involved? or should i just take it in to a sunroof Shop? Cheers |
14-03-2011, 05:20 PM | #2 | ||
Flairs - Truckers Delight
is yours one of the ones affected in the recall?
14-03-2011, 06:10 PM | #3 | ||
No..I had a tickford Sunroof installed 3 years ago.. Im surposed to have it serviced once a year but they are in town and wont service on Saturday`s.
They want the car for half a day but the service takes 45mins..The problem is i have to take the day off work.. If the sevice isnt that hard id do it myself.. just waiting on here for a answer .. do it myself job or is it a `too hard` job! If it is., ill just take the day off and have it serviced. Cheers |
14-03-2011, 07:28 PM | #4 | |||
AU DIE HARD
Is the service a freebe or are you paying for it ? if your paying for it there are plenty of reputable sunroof dealers around that will service it , I presume its a Hollandia (splelln)
14-03-2011, 09:39 PM | #5 | ||
check here to make sure it's not covered "Hollandia 700 sunroofs manufactured from 2002-2009" are covered by the recall so you might be lucky
[SIGPIC][/SIGPIC]
15-03-2011, 06:00 PM | #6 | ||
Hey thanks ..au3xr6..
Checked the serial number and the glass has to be replaced..So ive booked the car in for the sevice as well.. Cheers |
10-10-2015, 03:14 AM | #7 | ||
drive hot Cars just cause
ford just had to reprogram my keys and ****** the lot up, changes my bcm, ecu etc, So eversince my sunroof aint worked,, ive argued with then but they know best,, ,my ***,,, ****en tried to charge me 1800 bucks when i just towed it there and said my keys have been flogged out of my house.,,, ****en I take it the BCM they used isnt programed for a sunroof,, ill try n by pass it,, if so
