Old 09-01-2007, 12:20 PM   #1
schwartzy
Default Help locating speedometer cable for Sat Nav install
I am about to install a blaupunkt dxv satellite navigation system in my xt and i need to locate a speedometer signal wire. I believe there should be one going to the radio. Can you help identify the correct wire?
schwartzy is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 12:52 PM   #2
ASLTech
This wire can be located on Front Passenger side kick panel. Locate 565B-W(Black Wire with white stripe) and splice the wire at the back of the connector C-119.
ASLTech
ASLTech is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 01:14 PM   #3
schwartzy
Thank you for the prompt reply. There is also a back-up lights signal wire that needs to be connected. I assume this means reversing lights. Why would this be needed. Have you installed a balupunkt dvx system? Can I get ball park price for installation?
Old 09-01-2007, 03:06 PM   #4
ASLTech
You only need the reverse wire hooked up if you plan to add a external reverse camera. If not don't connect wire-we don't. We currently only install VDO so I couldn't quote correctly on installation. Sorry.
Old 09-01-2007, 03:45 PM   #5
schwartzy
Thank you for yor help.
