Old 29-12-2006, 06:36 PM   #1
Damo
Default EF Belt tensioners bearings ?!?!
can the bearings in the idler pulleys on the tensioner be replaced or do you have to replace the whole tensioner. One of mine has become very squelly and it's annoying the crap out of me. Just hoping I don't have to replace the whole tensioner.
Cheers,
Damo
Old 29-12-2006, 06:43 PM   #2
efgiar
rofl copter
efgiar's Avatar
ull probly find its wear in the tensioner puller wear the bearing is. u may be able to replace them but not sure if the pully would break before the bearing comes out, a press would be the only way to get it out too id say
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 06:50 PM   #3
Jason[98.EL]
Jason[98.EL]'s Avatar
yes damo you can
i have replaced them in the past but there is a trick ti it
if you come down in the morning we can pull it off and replace it for you if you want
jason
[SIGPIC][/SIGPIC]
Old 29-12-2006, 06:55 PM   #4
Damo
bugger. :( Might try source a second handy.
Old 29-12-2006, 07:36 PM   #5
Damo
Thanks for the offer Jason, but I don't have a new bearing and i'm broke and won't be attending tommorrow. Can you tell me the trick, and do I need a press to replace it ?
Old 29-12-2006, 07:41 PM   #6
Jason[98.EL]
yes you need a press to do it you also need a die grinder to release outer lip
its not that easy i would get secondhand one to tie you over
then when we get a chance ill show you how to do it
jason
[SIGPIC][/SIGPIC]
Old 29-12-2006, 07:54 PM   #7
Damo
cheers, i'll price up a new one and a second hand one and go from there.
Old 29-12-2006, 08:59 PM   #8
Gubas
- BOOYEH -
Gubas's Avatar
I have a second hand one for ya Damo. Its yours if you can get down here and get it.
1993 EBII Fairmont Turbo T04e 7 psi
Gubas is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2006, 10:40 PM   #9
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Cheap Solution
Take pulleys off the idler
Carefully flick out the bearing covers with a sharp knife
Clean properly and repack with grease, replace covers
Flip pulley over 180 degrees when reinstalling on idler as one edge of the pulley is usually less worn from the belt than the other especially when car has a few kms up.
I do this every 30000kms on taxis, pulleys last for about 200000km normally which is when you have to replace idler anyway and when you buy it from Ford (about $120 I think) you get 2 new pulleys
A dearer solution and needing more tools is to press out bearing from pulley, go to bearing store and get new bearing for $5 or so. Can also get metal pulleys from bearing stores, these tend to last a bit better I have found as they deal with heat better than plastic, about $30 to $40 from memory.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 12:52 AM   #10
Damo
thanks for the advice guys, Gubas I might take you up on that offer. My car will be off the road for 6 months anyway as of late January so not too fussed about it now.
Old 30-12-2006, 01:16 AM   #11
Gubas
- BOOYEH -
Gubas's Avatar
No worries. I'll bring it up to the next cruise if your going
Old 30-12-2006, 01:56 AM   #12
niko
likes falcon's
niko's Avatar
or just buy them premade...lol was around 50-60 for brand newies for mine
www.carhubsales.com.au
Old 30-12-2006, 11:50 AM   #13
EDXR6T
Originally Posted by Damo
My car will be off the road for 6 months anyway as of late January.
Turbo.?
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 11:55 AM   #14
John_LS1
loss of license?
