Old 15-10-2006, 06:15 PM   #1
zyweik
zyweik's Avatar
Default laser front disks
Hi guys..
my mate has a 91 laser.. we have to change over the disk rotors and pads on the front cause they are stuffed..
could someone please give me a guide on how to do this? ive done rwd cars before and this is easy becuase you just take the front hubs off etc.. whats involved in getting the rotors off (i.e. take off hubs?, driveshaft? etc)
cheers in advance
zyweik is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 10:38 PM   #2
el_sparko
turbo kid
el_sparko's Avatar
Take the rim off, on the back of the caliper you will find 2 bolts (14mm) that hold the caliper on the assembly. Undo them and the caliper pops right out. Im not 100% sure if the rotors are bolted to the knuckle by a single 18mm bolt or not but either way they pop right out...
Replacing the pads is just like any other car, unbolt a single nut on the caliper that holds the flap bit in place. Open the flap, pop out the 2 rods and the metal wire out, pull old pads out, put new ones in and reverse the above process... youre done.
el_sparko is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2006, 11:06 PM   #3
zyweik
zyweik's Avatar
so no taking off hubs like on my galant then :P
im sure i will work it out lol.. just wanted to make sure i wasn't dealing with taking parts of the driveline off haha..
cheers bud
Old 08-11-2006, 06:42 PM   #4
TheKeTx3
Tx32be
yeah are pretty simple to do .... lasers are pretty easy to work on in general .
TheKeTx3 is offline   Reply With Quote Multi-Quote with this Post
