Old 17-02-2005, 01:11 PM   #1
XR6Silver
Exclamation Any AU XR6 Defualts?
Hi all.
I am currently about to purchase my Au Xr6 99 model. Does anyone know any defaults with the model. Oh and Russ if u are reading this where is that sort of info on this forum?
Xr6Silver
Old 17-02-2005, 01:38 PM   #2
Dauphin
Irregular member
Dauphin's Avatar
You mean like defects? Things wrong with it?
Old 17-02-2005, 01:56 PM   #3
Casper
Contributing Member
Casper's Avatar
Originally Posted by XR6Silver
Hi all.
Xr6Silver
Is it an XR6 HP or XR6 VCT?
99 model, is that an AU1 or early AU2?
There is an etire section under aufalcon.com that is dedicated to the AU and will be able to answer everything you want hopefully.
Older, wiser, poorer.
Old 17-02-2005, 03:38 PM   #4
loxxr6
XB in parts...
loxxr6's Avatar
Try checking here :
https://www.fordforums.com.au/showthread.php?t=646
Old 17-02-2005, 07:04 PM   #5
XR6Silver
It is a series one with the round lights and i think its just the V6. So yeah any problems with that model!?!?!?!?! Cheers
Old 17-02-2005, 07:16 PM   #6
sbutler
335 kw of goodness
sbutler's Avatar
V6?? Oh dear
CAUTION!
STILL Contain's opinion's & fact's that may offend !!!
2012 GTP 213 black what was I thinking? NOW FOR SALE>>
http://www.fordforums.com.au/showthread.php?t=11439680
sbutler is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2005, 09:00 PM   #7
b2tf
not here much anymore
b2tf's Avatar
V6? Yikes, dont say that too loud!
AU1's pretty much have the same problems regardless of what model they are, the main ones being the suspension and the brakes (and the styling if you ask some people!).
Depending on whether it is an IRS equipped model or not (unsure if any AU1 XR's were though), check the shock towers and mounts, and definately give the brakes a good once over as well.
2024 F150 XLT
Old 17-02-2005, 09:13 PM   #8
jonbays
TL40 Wagon?
Intech, Inline 6, I6, SOHC 6, VCT, but not a V6!
Old 18-02-2005, 10:27 AM   #9
loxxr6
XB in parts...
loxxr6's Avatar
I had to watch out for a rattling in the engine which worked out to be cracked guides. Other than that I upgraded my brakes with better pads and there's really been no other problems with the car.
Old 20-02-2005, 03:28 AM   #10
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Check the condition of the window seals, particularly in and around the top of the rear doors, the windscreen etc etc.
I'm hoping your V6 translates to VCT 6 he he.
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2005, 07:53 PM   #11
XR6Silver
Default Cmon explain
Whats wrong with just V6???Please someone explain!!! Cmon im NEW!! :
Old 20-02-2005, 08:01 PM   #12
RED_EL_XR8
RED_EL_XR8's Avatar
Fitting of a V6 would certainly have voided any factory warrantee
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2005, 08:07 PM   #13
Casper
Contributing Member
Casper's Avatar
The V in V6 is in relation to the engine configuration. Like a V8. However, in the Falcons the engine configuration is a inline 6. This means all the pistons are set in a direct single row from front to back. Therefore the engine is referred to as an Inline 6 or I6 for short. The Holdens have a V6, where there are 2 banks of 3 pistons joined at the bottom in a V confuguration.
If you get a chance, pop the bonnet and have a look at the XR6. You will see the red Rocker cover and 6 leads going to the spark plugs of the 6 cylinders. As you will see each cylinder is directly behind the other. On a Commodore if you get a chance to see one there are 2 seperat cylinder heads (covering 3 cylinders each).
Hopefully this explains why we refer to the Falcon 6 cylinder cars as an I6 rather than a V6.
Its all good, everyone has to learn sometime. Anything else you want to know please feel free to post or PM me.
I hope everyone else in here realises that we all have to learn some time and it should be encouraged rather than laughed at.
Old 20-02-2005, 08:15 PM   #14
XR6Silver
Hey thanks Casper. Learning the way a Ford ticks is a whole new learning path! that makes so much sense. Is there more power with I6 rather than v6? and whats all this VCt and Intech???
And thanks to David for the reply! :1syellow1
Old 20-02-2005, 08:25 PM   #15
Casper
Contributing Member
Casper's Avatar
Ok, power wise the Falcon I6 has, in general, had a greater kw output and Torque output than the corresponding Holden. The Holden has usually kept the 0-100 and ¼ edge by having slightly better gearing and a lighter weight…although this starting to even out.
As for the VCT/Intech/HP type of engines. There were, in the AU, 3 types of I6 engine. The standard Intech 6, as seen on the majority of Falcons. The HP, used only in the XR6 HP model….an uprated (improved head, more aggressive cam) version of the Intect6. Finally there was the VCT. Used in the XR6 VCT, the Fairmont Ghia and the Fairlane Ghia (and LTD I think), it was the most powerful of the stock I6 engines due to the VCT (Variable Cam Timing) in it. It is, also, the least understood and least modification supported engine of the 3 as there really isn’t any aftermarket cams to upgrade to. While being more powerful, all the VCT equipped cars were also fitted with the fantastic but very heavy IRS rear suspension. While improving the ride noticeably it also added enough weight to make the XR6 VCT slower (by about 0.3 of a second) than the XR6 HP.
Old 20-02-2005, 08:38 PM   #16
sbutler
335 kw of goodness
sbutler's Avatar
Arr: What would we do without casper?? LOL
CAUTION!
Old 20-02-2005, 08:42 PM   #17
Casper
Contributing Member
Casper's Avatar
Thats my role, to help out and make new members feel at home.
Old 20-02-2005, 11:44 PM   #18
XR6Silver
Yeah thanks Casper. Its people like you that have converted me to Fords. Pitty about others on this forum who were magically born with all the Ford automotive knowledge and use this forum as a boast board rather than an informative forum. They know who they are and I rest my case
Old 20-02-2005, 11:47 PM   #19
Casper
Contributing Member
Casper's Avatar
Not a problem, happy to help.
Ford fans, especially AU ones, are more than welcome.
Check out www.aufalcon.com
Heaps of goodies and idea's there.
Old 25-02-2005, 03:06 PM   #20
Mr Cube
Mr Cube's Avatar
So have you bought the car yet..
From experience the brakes are no good and the suspension is too high..
Best thing I did was put on DBA Slotted Rotors combined with some better pads that improved the braking significantly.. The suspension I waited until it was driving like a boat: ie the shocks were stuffed//
Koni Shocks, Super Low King Springs and it handles much better.. Could go low but you are going around the same height as the AU2&3 XR's, personal preference though, was tossing up the idea of SSL but the roads that Im mainly on are not really that good
Have you got an FPV or XR6/8 and live in the ACT or surrounding area? Come and check out the FPV & XR Owners Club of ACT
AUI VCT:
To date - Big brake upgrade, Koni and Kings all round, 2.5 cat back ready for replacing, 19" again ready for replacing.
Planned - Too much now I got the baby back.
Mr Cube is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2005, 04:02 PM   #21
loxxr6
XB in parts...
loxxr6's Avatar
Yeah I only have King Lows 32mm drop and suddenly the ride is a lot harsher. I also don't have IRS...
Slightly off topic, whats the verdict on braided brake lines for our cars. Are they worth it ? I was told the pedal feel would be better.
Old 25-02-2005, 04:31 PM   #22
DivHunter
DivHunter's Avatar
braided lines don't expand like normal brake lines, so theoretically there should be better braking and pedal feel
Speed cameras have changed the things we pay attention to and the things we regard as important. Instead of focusing on the dangers ahead, motorists feel that they have been relieved of responsibility for managing their own driving, and have ceded it instead to the mechanical intervention of the camera and other traffic signals.
DivHunter is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2005, 09:18 PM   #23
GK
Walking with God
GK's Avatar
Thumbs up
Casper,
I really appreciated your response to silverxr6. Very understanding, and willing to teach. Everyone starts with no knowledge and needs someone with the time and inclination to teach.
Cheers.
Old 23-03-2005, 09:24 PM   #24
Casper
Contributing Member
Casper's Avatar
If it gets another person into an XR6 AU its worth the effort.
When I first joined I only knew the basics myself, we all have to learn at some time.
Old 23-03-2005, 09:44 PM   #25
Bucknaked
Bucknaked's Avatar
As the resident Nancy boy, if you want it too look pretty, i'm your man. If you want it to go hard, then Casper is the guy you need. Cubie is our height specialist, JC is our modification specialist. SButler is the critic specialist. We got all sorts around here. Welcome to the club :
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 23-03-2005, 09:45 PM   #26
Casper
Contributing Member
Casper's Avatar
Originally Posted by Bucknaked
If you want it too look pretty, i'm your man. If you want it to go hard, then Casper is the guy you need. Cubie is our height specialist, JC is our modification specialist. We got all sorts around here. Welcome to the club :
Bluedriver, the man for rims.
Old 23-03-2005, 09:46 PM   #27
Bucknaked
Bucknaked's Avatar
Theres a huge list of AU experts. We are all knowledgeable in our own fields.
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 23-03-2005, 10:03 PM   #28
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Hints & tips on how to keep that AU clean, can always talk to Strider!
Of coures if you're up for how to preserve demerit points in an AU, you can come see me.
Old 23-03-2005, 11:40 PM   #29
GK
Walking with God
GK's Avatar
Smile
Thanks again.
It's really hard to understand you know, why the AU was so maligned a car. I know the original Forte looked pretty off with the Baleen Whale Fish Grille and all, but I really like the lines of the other models. I often stare at the shape of my Au Futura Wagon and think, man that's a nice shape.
I guess it was too radical for the conservative Australian public.
Cheers.
P.S Casper, have you seen my thread "make the knocking stop?" I would appreciate your opinion, it seems not many have responded.
Old 27-03-2005, 09:12 AM   #30
xr8 007
xr8 007's Avatar
[/QUOTE]If it gets another person into an XR6 AU its worth the effort.
When I first joined I only knew the basics myself, we all have to learn at some time."
Although i dont post that much i certainly go through the forums for advice etc. Casper your efforts have certainly put another person in an au II xr6. Being a p plater i'm into fast jap turbo's and the usual commodore. But after heaps of research and test driving i feel in love with the 01 AUII XR6 vct. what pushed me to really get it was your impressive quater mile times, help and mods that u have done on the car...Thanks a bunch mate!!!
HERM...............................
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
