23-01-2006, 10:32 PM | #1 | ||
hunting 300kw's
VZ SS w/New L76 260kW/510Nm V8
-------------------------------------------------------------------------------- MORE GO FOR HOLDEN’S PERFORMANCE HEROES The most powerful standard engine ever offered by Holden will be installed in all 2006 model year Holden V8 vehicles. A new 6.0-litre alloy engine will deliver 260kW of peak power at 5600rpm and 510Nm of peak torque at 4400rpm across all V8 variants in the Holden range. Torque delivery is significantly increased at lower revs offering improved acceleration, low speed engine response and improved ease of towing than the previous 5.7-litre engine. Codenamed L76, the new engine is a member of GM’s fourth generation small block V8 family. The 2006 Holden range is the first application of L76 within General Motors around the world. The L76 will be available in SV8, SS, Calais and Berlina sedans, Statesman and Caprice prestige vehicles, Berlina wagon, Ute SS, Crewman SS and Crewman Cross8. This offers power increases in all new vehicles compared with the 2005 variants. Commodore SS sedan and SS Ute receive front and rear performance brakes standard whilst SS Crewman adopts performance front brakes. The front rotor is 320mm x 32mm vented compared with 296mm x 28mm vented on the previous standard system. The rear rotor is 286mm x 18mm vented compared with 286mm x 16mm solid. The extra performance will be managed with better breathing sports exhaust and significant improvements to automatic transmission characteristics. From an environmental perspective, all new variants meet strict ADR79/01 emission regulations which came into effect on 1 January 2006. GM Holden Chairman and Managing Director, Denny Mooney, said the new powertrain continued Holden’s evolution as the leader in affordable V8 performance. He said low end torque and responsiveness took the V8 models to a new level which delivered performance and economy to owners. “The extra power is mainly noticeable where it’s most useable down low in the rev cycle,” Mr Mooney said. “We’ve heard what our customers have been saying about useable torque and the new L76 engine delivers that well. The cars deliver excellent power-to-weight ratio and we’ve also managed to retain the impressive fuel economy which the Holden V8s can deliver.” Details of the L76 engine, which will be manufactured in Mexico, were announced in NorthAmerica in late 2005. The powertrain will also be installed in 2007 model year sports utility vehicles for the US market. The L76 incorporates several significant changes to improve performance compared with the 5.7L LS1 third generation engine it replaces as the heartbeat of Holden’s V8 fleet. Key changes include - • All-new aluminium cylinder block casting • Cylinder bores measuring 101.6 mm in diameter, combined with stroke of 92.0 mm • Revised high-flow cylinder heads deliver the airflow necessary to complement the engine’s larger displacement • 55mm inlet valve and 40.4mm exhaust valve diameter • Flat-top piston design • Compression ratio raised to 10.4:1 from 10.1:1 • More efficient ignition coils require less energy to provide a comparable spark • Larger, 90-mm single-blade throttle body • Revised and more powerful engine controller incorporates electronic throttle control • External knock sensors Significant testing and calibration development requirements mean Holden has not initiated cylinder deactivation technology. The V8s will be mated to the reliable 4L65-E four-speed automatic transmission which has been revised with an input shaft speed sensor. The speed sensor noticeably improves shift quality and consistency under varied conditions, particularly low throttle. The Tremec T56 six-speed manual transmission has a revised clutch plate and pressure plate for transmission of increased engine torque. Start of production of MY06 variants starts in February at the Elizabeth, South Australia facility following $35 million of upgrade works during the Christmas and New Year break. More than $400 million has been spent on the SA manufacturing operations in the past three years. Model year 2006 changes – V8 variants SS sedan VZ Monaro CV8 alloy wheels (including spare) – standard Performance brakes front and rear – standard Performance exhaust – standard Leather seats – standard Silver Grey accent stitching on steering wheel, gear knob and handbrake handle on all interior combinations Rec. retail price $51,790 excluding government and dealer charges Ute SS Performance brakes front and rear – standard Performance exhaust – standard Devil Yellow colour new to Ute Rec. retail price $41,490 excluding government and dealer charges Crewman SS SS Crewman adopts performance front brakes Performance exhaust – standard Rec. price $47,690 excluding government and dealer charges |
23-01-2006, 10:35 PM | #2 | ||
Cobblers!
Still 4 Speed, no Tiptronic.
I like the idea of Standard leather, but think of the weight. It also looks the same as an Executive. Atleast the XR looks Different from the Povvo Pack.
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
23-01-2006, 10:37 PM | #3 | |||
AFF's 1st DM.......
Trying to keep up with the joneses
Not bad pricewise... Whats a new XR8 worth anyone??
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
23-01-2006, 10:42 PM | #4 | ||
I read in motor they will be using the same ZF six speed auto as the falcon, I hope they do, the gearboxes in the commodores and falcons just haven't been up to scratch I think.
23-01-2006, 10:56 PM | #5 | ||
An Old Boss™©
Wonder what spin Ford PR will put on the Boss260? "Still the Boss"???!?!?!! ROFL!!!
Where did I go? What was I doing there?™© |
23-01-2006, 11:12 PM | #6 | |||
FF |
23-01-2006, 11:15 PM | #7 | ||
Hmmmmmmmmm
Makes me kinda want one LOL
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
23-01-2006, 11:23 PM | #8 | ||
How good would a VZ 6.0L Berlina be with 16 inch alloys, ud burn just about any stock Ford V8 in that, providing you could get traction.
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA Jan 25. |
23-01-2006, 11:24 PM | #9 | ||
SSuper SSpy
would be the icing on the cake if they used a 6 speed auto
23-01-2006, 11:27 PM | #10 | ||
I reckon that looks good. Hope it does well in terms of performance.
23-01-2006, 11:31 PM | #11 | ||
Oh Yeah!
Still gotta laugh at all the people who fell for the vz ss z or what ever it was. Just a chance for holden to get rid of the old 5.7lt as quick as the could.
Oh no! Duffman can't breath! Oh, yeah! |
23-01-2006, 11:38 PM | #12 | |||
24-01-2006, 12:13 AM | #13 | |||
Cobblers!
They are using the Current 4 Speed, with minor changes, similar to what Ford did to the Ion box.
24-01-2006, 12:30 AM | #14 | ||
And the weight is????
Cheers Jim
BAXR8 A4.......CAI....CATBACK......10,000k's and real tyres at 29psi = 14.057 with a virgin driver :the_finge |
24-01-2006, 12:33 AM | #15 | ||
hunting 300kw's
no idea on the weight jim... lets just hope this makes ford increase to boss 290 XR8
24-01-2006, 01:51 AM | #16 | |||
24-01-2006, 02:01 AM | #17 | |||
cross breeder
Like xk-xf's?
http://www.ozfalcon.com.au/ |
24-01-2006, 03:29 AM | #18 | ||
DJR TM#54
Well Ford will need to pull it finger out if they are going to keep up with that new list of standard equiement & performance. Ford doe's not need more peak power but more low end torque.
But Holden still has that horrible steering wheel with those hard edges on the fork going to the rim.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains |
24-01-2006, 09:04 AM | #19 | ||
Right out sideways
Have they gone back to how Ford and Holden did it in the early 90's, one motor for any car with a V8 ? (ie: VN Exec 165kw V8 was same spec as SS, and EB XR8 165kw was same as std V8 too)
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
24-01-2006, 09:17 AM | #20 | |||
24-01-2006, 09:45 AM | #21 | |||
Cobblers!
Note to self: use emoticons
24-01-2006, 09:55 AM | #22 | |||
Right out sideways
although there was talk of a ZF factory/assembly in S.A ?
24-01-2006, 10:04 AM | #23 | ||
Virtuous Bogan (TM)
Why one gods name would GM use ZF when they have developed their own....
24-01-2006, 10:16 AM | #24 | ||
This was news like 3 months ago
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
24-01-2006, 10:34 AM | #25 | ||
T3/Sprint8
Great package all round imo....
24-01-2006, 11:07 AM | #26 | ||
Who cares anyway, its a band-aid car which will only be avalaible for a few months anyway. VE gains alot of weight on its release which will significantly knoble any advantage it had.....
335 S/C GT: The new KING of Australian made performance cars.. |
24-01-2006, 11:14 AM | #27 | |||
I mean yes, a 6L in a light body is something but it is one hell of a risk buying Holdens first attempt at this engine given their track record with the LS1 problems that wernt solved for a long time. Basically ou would be a test mule for VE. As performance enthusiasts we can now see the advantage of the SS over the XR8 BUT what about Joe Average - do you think he will see the Holden has a 6L V8 that has the SAME power as the Ford 5.4L and think "well they make the same power, may as well get the smaller engined ford as i dont want to pay fuel bills for the 6L" ??
24-01-2006, 12:06 PM | #28 | ||
T3/Sprint8
Oh come on guys its still a good package even if it is old.
Why would you buy one ? Like I did for my AUXR8 at RUNOUT time, got me into something was a little out of my budget but thankfully then I could. The last Series has no worries usually and you end up getting extras at no cost ! I for one was not into BA at the time and would never buy a first Series anything. LS1 had it's issues but so did Boss didn't it ? Yes Joe Average who usually buys this type of car knows of engine size and I'm sure the saleperson will advise them also. As for "fuel bills" we wouldn't be buying new 8's if fuel was an issue and majority of these buyers are company owned.
24-01-2006, 01:42 PM | #29 | |||
The Series prody guys prefer the 5.7 for racing too. Dont forget its only just matched the BAXR8 power figures now anyway!
24-01-2006, 03:16 PM | #30 | |||
FF Last edited by Falcon Freak; 24-01-2006 at 03:25 PM. |
