Hey I got a AUII fairmont and the breaks squeel real bad. Can anyone suggest how to stop this or at least reduce it? The break pads are not old and a mate last week took the breaks off and put some red (can't remember the name of the stuff) on the worn metal parts to stop them from squeeling but it didn't help.
(i'm not up to scratch on technical terms hahaha) Any help would be appreciated. Cheers Dave |
Not sure if AU pads are the same, but we have an issue on the Liberty/Outback front brakes. There's a slit in the pad, it fills with dust. Clean it out and it should improve. If the AU's have it.
Boost Addict
change brand of brake pads, cheaper brands have the bad habit of producing a lot of rake dust and squeal a lot. and yes there is a slot
any sugestions as to what brand of break pads to get????
#5 | |||
Highway Taxi
Just put Bendix Advance on the wagon last weekend to replace a set of squeeling Zircons that were fitted by a mechanic. The Zircons didn't have a slot acroos the pad but the Advance have two slots. Much better than the ones they replaced, well so far anyway. I've only done about 150ks on them so time will tell. But so far so good.
Boost Addict
i am using metal kings on my race brakes (330mm rotor with twin piston caliper), and use bendix ultimates on the rears. I am also using RDA Level4 pads on the rear of my subi and RDA metal kings on teh front. Only the RDA metal kings on teh front of teh subi squeek a little after a big workout, all others are quite as, but very dust items.
the slot in teh middle of the pads actaulla shifts the brake dust to teh outside of the pad, rather then getting trapped between pad and rotor. further i must say that all my rotors are at least slottered, which helps a lot with the removal of dust between pad and rotor |
Still alive & kicking
The squeeling is caused by viabration of the disc pad against the roter where the break dust gets traped.
Remove pads remove dust then apply anti break squeel spray to rear side of disc pad let dry for 30 minutes then re instal.
EL XR8 made to burn rubber :evilsasmo IN THE BEGINING THERE WAS TICKFORD |
Did that, still squeeling real bad
Thanks anyway, cause it will probably help in most cases |
Do what I did. Get rid of the squeelers and put the Bendix Advance in. End of trouble end of worry.
Sounds like a plan but
2 questions Should i replace all 4 sets to stop the squeeling? Where do i buy Bendix advance pads? Cheers |
#12 | ||
Where do i buy Bendix advance pads? If all 4 are a problem i probably would. Otherwise, just do the front first. I got them from Repco. Managed to get them at trade price $53.00 Steve |
#13 | |||
Boost Addict
#14 | |||
#15 | ||
15+ Years!
My S3 AU pads are H/Duty and squeal a lot but after driving the AU1 Fairmont they pull up a hell of a lot better so I'll be putting the H/D pads back on
AUII Fairmont Ghia Sedan Sparkling Burgandy Work in progress ![]() https://photos.app.goo.gl/7roViz57bb2Stkzx6 |
#16 | ||
Being a mechanic, I will suggest our correct way to stop squealing brakes. WASH THEM! It sounds silly but if you hose the dust off the brakes/rotors from under the vehicle, preferably with a pressure wash the probs will be solved untill the dust builds up again, dependant on how many track days you go to.....
#17 | ||
Washing them does nothing. The Zircons I had actually were becoming quieter until it rained and "washed" them. After things dried up they were actually worse than ever. Ive done probably a thousand ks on the Bendix Advance and not a problem so far. Best thing I did.
#18 | ||
Fasir enough. I meant actually getting under the car at Carlover's & blasting them but if it didn't work so be it. That is how I know when to wash ours, I hear the wife come squealin' down the drive....
What are Zircon's????? |
#19 | |||
This trouble with squealing brakes started in Feb when new pads & rotors were fitted. The car went back to the mechanic on 2 occassions. Once the pads were changed & the second time a rotor was changed. None of it made any difference until I put the Bendix pads on myself. |
#20 | ||
Yep Bendix advance are the go, I have had no squealing with them at all.
Although I am sorry to say you got raped at $53.00.I got mine for $41 lol. Other than that it only takes 5 minutes to remove and clean discs and pads.
#21 | ||
[QUOTE=our_blue_xr6]
Although I am sorry to say you got raped at $53.00.I got mine for $41 lol. QUOTE] Jees, I thought I was getting a bargain at $53. That was Repcos trade price to, so the retail price would have been more. Country NSW what can I say. They work thats all that I need. |
#22 | ||
buickman
I've used the ultimates from bendix but found they destroyed the disc faster & left brake dust on the wheels.
I'am now using the bendix Advance great pad for not leaving brake dust & as a few others have mentioned a good all round brake pad for daily use. buickman |
#23 | |||
I think thats my problem. Also using Ultimates. Does removing the brake dust from the Ultimates fix anything? Or is the only option to replace the pads? |
#24 | ||
So the amount you guys are saying it cost to purchase the pads, is that for each wheel?
#25 | |||
#26 | ||
They are a nightmare aren't they.
Mine started at 4,000 km and I did everything that has been suggested on this thread for zero result. Got on to EBC's Red Stuff for the front and Green Stuff for the rears - no problems since. The standard pads that Ford use on their new cars are absolute rubbish and whoever makes them should be drummed out of the business (then again if Ford didn't use them they would be outa business) Red Stuff are a ceramic compound and are not as dusty as Green but they are a bit dearer. Unless you can get them trade expect to pay $165 for a set of front Greens and $115 for rear Greens. The front Reds will sting you for about $275, but it's worth it to stop that bloody squealing. Check the EBS website www.ebcbrakes.com Good luck |
