25-09-2021, 11:58 AM | #1 | ||
So i have an au2 falcon xls manual ute and have a 3.45lsd diff from an xr6 and wanting to change over to an open diff.
Would I have to replace the whole rear end or can i swap the centres over and whats the procedure for that. |
25-09-2021, 04:42 PM | #2 | ||
64 Deluxe 4 door
Ute is leaf springs. Sedan is coils I assume the XR6 is a sedan?
Diff centres can be swapped but they need to be set up properly with clearances, backlash etc. Not something I'd attempt without help and especially if you've got to ask.
XM Deluxe FG XR50 BA Pursuit Ute |
25-09-2021, 06:45 PM | #3 | |||
I get that you have an AU2 XLS manual ute. It appears you also have a 3.45LSD out of an XR6. It sounds like the LSD is installed in the ute, as you want to change over to an open diff. So what's the question again? |
25-09-2021, 07:01 PM | #4 | |||
27-09-2021, 07:27 AM | #5 | ||
If you change the gears over you have to set the backlash to loose it will chatter to tight it will howl like a mongrel dog google setting backlash it will scare you
27-09-2021, 09:13 AM | #6 | ||
Regular...with metamusal
grab another diff [that suits] & play with that.
