Hi guys and girls.
Just hoping for some advice on towing a Caravan and car mechanical safety. I now have a VW R36 (I know not a Ford had a decade with a BA Turbo) and been looking to buy a Caravan for a while. It's a 16ft older (but immaculate) Millard and according to booklet the R36 can tow it legally up to 2500Kg braked which complies. Just opinions I'm hoping for but do you think a Caravan too much for a car tranny and engine? Especially a VW with DSG? Would only be used for short easy trips up to 100Ks max. All advice as it's a brilliant buy and what I've been looking for, but if too risky to car then no worries. Thank you all. |
#2 | |||
Thailand Specials
But at the end of the day if the manufacturer says it can tow up to 2500kg then it is fine to do so. The first step is to get your hands on VW's trailer wiring kit and then change over the useless Euro trailer plug to a 12 pin with a reed switch to disable the reverse sensors or a 7 pin + 50A anderson connector. |
2 users like this post: |
HUGH JARSE
![]() Join Date: May 2005
Is this a wind up?
3 users like this post: |
#4 | |||
Rest of advice much appreciated. Those kinds of changes would be completed for sure to get it to happen. You know your stuff!! |
2200kg braked sorry guys not 2500 like I said
The Terrain Tamer
![]() ![]() Join Date: May 2013
A typical 16 foot Millard probably wouldn't be more than 1000kg TARE weight, then you have the ATM, which is what you are allowed to add to the TARE weight. In the older vans, it's usually not that much - maybe 200 - 300kgs, so technically, you probably won't be towing over 1,500kgs.
Have a look at the rego papers and see what your TARE & ATM weights are as a starting point. The other thing to remember is that the older vans were built like a brick (very little aero), so there will be a lot of wind resistance too, which will add to the towing stress. Auto transmission coolers are also recommended if you are towing regularly.
Current Ride : A Ford owned D3... Last edited by Beastie; 02-05-2020 at 07:43 PM. |
Honestly if it was me I wouldn't be towing it with that rig
Had EB XR8 AU XR8 220 (awsome car ) AU Fairmont BA MK2 XR6 Turbo Now XDUB |
#9 | |||
Yep owner said it weighed around 1400 so your specs sound completely spot on. Ok cool I will look at those ratings - I thought towing capacity was all that was legally required so I'll look into it. Yes I knew on a cooler but the local caravan place said not required if only towing 10 times a year max for only an hour. That may be wrong. Thanks again BB. |
It's not ideal I know - I was just asking as not keen to sell it for a tow vehicle if I can get best of both worlds (it's already towed a boat for years from previous owner, hence all the towing equip on it alteady and no problems at all)
#11 | |||
The Terrain Tamer
Edit: Here is a link that will help. http://www.withoutahitch.com.au/cara...wing-capacity/
Current Ride : A Ford owned D3... |
#12 | ||
BA/F6 BF/F6 SSV/R TTG
I only tow with a heavy vehicle with good brakes. Its all good until you have an emergency.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
#14 | |||
The owner has towed with a Commodore auto for over 10 years so I thought it might be ok |
#15 | ||
No thats just my opinion. Do the research and find out what others are towing with that vehicle.
I towed a 3T 4WD with my territory. But that car is set up for it. Massive engine and gearbox coolers and tuned gearbox. Also has big brakes.
#16 | ||
Yep ok no worries. I doubt many use any Euro performance cars for towing just didn't know a small van would be much of a problem for short trips.
#17 | ||
Trans cooler is for a transmission, NOT DSG.
But make sure your gearbox is serviced properly. I would tow that with my Mondeo, I don’t see a problem. Get onto the water cooled VW forums for some more informed advice.
Steve Current rides 2012 Mondeo Titanium wagon (TDCI) Moondust silver 2016 Focus Trend, 1.5ecoboost, 6sp manual. Frozen white Previous 2004 Berlina Wagon (LS1) Vespers Blue 1995 Camry 2.2, white 1971 Ford Fairmont wagon 302w, C4 Polar white 1971 TC Cortina, 2L 4sp, Ermine white |
#18 | |||
I didn't with mine either as per your Mondeo, but now I'm scared as.....ha. Will do but those forums aren't much help as R36s are pretty rare here and I doubt many tow....... |
#19 | ||
Looking for clues...
Myself and my wife (I'm not taking full blame for this...) bought a yacht on a trailer, and then found out my FG/X ute with nearly 299kw couldn't tow it. WTF? I only had just over a tonne of weight I could tow with my YouBeautUte.
I still don't know why, whether it's the drivetrain, suspension or what... a fellow FordForumer offered his RTV ute which delivered the yacht really well. I scoured FB marketplace and bought a Jeep Grand Cherokee 4.7 V8 for $1250. The suspension was shagged, and I've spent maybe another $1500 getting it up to acceptable performance, but I think it's cheaper than upgrading either my wife's car, or ... no I'm not getting rid of the ute! My yacht is around 1800-2000 kg,
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
#20 | |||
4 users like this post: |
#21 | ||
Thanks guys.
Guess it's a bad idea even if only used sparingly for nice short weekend trips. I knew it couldn't pull a big one etc or long range but seems a no go at all and that's ok. |
#22 | ||
HUGH JARSE
In my first post I asked if this was a wind up.
I have had two caravans and three tow vehicles, and as with anything in life when you try something new there is always a progression. If your car can legally tow the caravan then you are off to a good start. You say you will only be towing it 100kms. That won't be a problem, provided you get the braking sorted out (does the caravan have electric brakes or override brakes?) get additional mirrors and maybe a weight distribution hitch if the bum drops under the load. Also check the towball download weight which is usually quite low on European cars - check your car manual. And finally check your car manual regarding other limitations in towing, my guess it will have a limit on speed. So you get all that settled and off you go for a few days in your caravan and let's say you have a good time. This is where progression comes in. You now wish to have a better tow vehicle. Your wife doesn't like the porta potty, she now wants an ensuite. You want A/C and TV. You go and look at some other BIGGERER AND BETTERER caravans for sale, they want to give you a good trade in price for your newly acquired tiny ****box of a caravan. But it is only 2500 kgs. Add your stuff - 300kgs Two water tanks -200kgs Suddenly you now need a tug that can legally pull 3000kgs. ![]() Oh, why not go the whole hog and get a 5th wheeler. ![]() Welcome to the world of caravanning, if you are not grey you soon will be. |
8 users like this post: |
#23 | |||
I am a caravanner and this is a very hot topic - many people don't understand this important fact. Many are now being put over a weighbridge by wise Police
I reserve the right to arm bears
#24 | ||
I tow a 1.9 tonne caravan with a Captiva. No issues in 39k/kms. I tow to Holden recommendations. If VW say "2500kg" then it should be okay.
BMW X3 can tow between 2000kg and 2600kgs. Depending on engine and transmission. Welcome to the fun of happy hours....
CSGhia |
#25 | ||
If I had a vehicle that couldn't or I would be worried about towing with it for 1 hour at a time I would no longer own that vehicle. To me it would be completely useless.
#26 | ||
Falcon RTV - FG G6ET
![]() Join Date: Mar 2007
I tow a 1400kg Van with a 330kw Turbo Falcon. No problems with it even at 110kmph down the Newell Hwy. Admit it a pop top:
![]() I've towed all sorts of stuff with the RTV; My Camper Trailer: ![]() This Stick Boat at Hwy Speeds: ![]()
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
#27 | ||
Pulling a big sail with a lightweight, short wheelbase hatchback, with a narrow wheel track and minimal payload rating... yeah, you should be fine! Can’t think of anything that could go wrong! ;)
#28 | |||
Although, by your avatar, a block of flats would appear small!
#29 | ||
#30 | ||
Yeah, I’ve sailed a Kombi in the past 😅
