Old 28-08-2016, 03:35 PM   #1
getmo30
Default Video and audio conversion territory
I have just installed a Colour ICC into my territory it has this extra plug under it is this where the kit plugs into the icc?
Note this is not from my car but the plug looks the same
Also the video in for reverse camera can it come from anything that has RCA?
or does it have to be NTSC or PAL?
i already have a camera installed into a double din under icc be good if it could just plug that one straight into the kit
Thanks
getmo30 is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2016, 11:29 AM   #2
FADI75
Sponsor
Default Re: Video and audio conversion territory
Thanks
Hi
Yes correct this is where rgb interface kit plugs in, the rgb kit got rca input and it will work as long ur camera is ntsc or pal ntsc switchable
Fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2016, 01:33 PM   #3
getmo30
Thank you
i think mine is ntsc/pal switchable
Old 09-09-2016, 02:57 PM   #4
getmo30
Hey Fadi i just got around to installing the video conversion kit today
all works except my camera almost seems black and white? except the guide lines are red and green, do you think this is the camera? because on my old headunit it wasnt like this.
Old 10-09-2016, 12:57 PM   #5
getmo30
Its not really black and white its just the colours are very minimal compared the the double din headunit i had , also it seems so bright that it cant really see only up close things are visible i tried turning the brightness down but it still cant see at a distance especially in the sun .
Old 12-09-2016, 08:42 AM   #6
FADI75
Sponsor
Hi
Could be the camera you are using, we dont have this issue using our camera
fadi75
Old 13-09-2016, 10:48 PM   #7
getmo30
Hey it seems someone else was having the same problem with you reverse camera kit using your camera? http://www.fordforums.com.au/vbporta....php?p=5508972
I wonder if this is a problem with the box?
Old 14-09-2016, 11:58 AM   #8
FADI75
Sponsor
Hi
This was all related to the camera he was using
cheers
fadi75
Old 14-09-2016, 02:59 PM   #9
getmo30
Ok thanks it seems they do something to the camera to make night time vision better, i have ordered a different one hopefully
it will fix this problem,
if not i was wondering if you sell your camera separately to the kit?
Thanks
Old 15-09-2016, 08:54 AM   #10
FADI75
Sponsor
Thanks
Hi
Yes we do, see how u go, if you require one please call us 0397991444
cheers
fadi75
Old 03-10-2016, 12:35 PM   #11
gippsweb
I never got around to changing the camera, it looks like the box has died since and I've not got around to looking into a solution yet..
gippsweb is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2016, 01:26 PM   #12
getmo30
how long did the video conversion box last?
Old 04-10-2016, 08:46 AM   #13
FADI75
Sponsor
hi
best if you call us to figure out the issue pls call 0397991444
cheers
fadi75
Old 04-10-2016, 02:30 PM   #14
gippsweb
Shall do when I get a chance.
Cheers Fadi..
