06-12-2013, 05:19 PM | #1 | ||
Anyone know?
06-12-2013, 05:28 PM | #2 | ||
I think I have read the ford and holden engines are about 480kw.
06-12-2013, 05:31 PM | #3 | ||
Thats about right http://www.v8supercars.com.au/champi...ehicle-details
06-12-2013, 06:32 PM | #4 | ||
Cheers, for that.
But does anyone know what they put down at the tyre? |
06-12-2013, 08:27 PM | #6 | ||
650hp
06-12-2013, 08:56 PM | #7 | ||
That's @ the flywheel though
06-12-2013, 09:35 PM | #8 | ||
- 40 hp then
06-12-2013, 09:38 PM | #9 | ||
I wish my cars only lost 40 hp thru the drivetrain !
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
06-12-2013, 10:03 PM | #10 | ||
Two turning.. two burning
gee shonky... lots of people posting.. but no one has the answer!?
we can all guess/work out drivetrain loss etc etc, but has anyone got figures of actual runs on a dyno and RWKW recorded! |
06-12-2013, 10:11 PM | #11 | ||
You won't find exact rwkw/dyno results, not of the current cars anyway..those are kept very close to the chest.
06-12-2013, 10:15 PM | #12 | ||
yeh, that's a fair point, you would think someone like a privateer or a car in the development series being dyno'd.
just an actual recorded figure would be nice. they may have less drivetrain loss than a regular road car due to gearbox design but it would still give an idea. |
06-12-2013, 10:42 PM | #13 | ||
335 kw of goodness
Almost all cars lose 50kw through the drive train..
CAUTION! STILL Contain's opinion's & fact's that may offend !!! : 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
07-12-2013, 06:06 AM | #15 | ||
I believed that they all used a torque sensor on the drive train so that they were all capped at a maximum horsepower to keep them more even. Of course the trick for a team would be to get the most useful power curve under that maximum limit.
07-12-2013, 01:50 PM | #16 | ||
no way mate unless you have the hand brake on or seized wheel bearings.
Race cars also have a super efficient drive train, 50kw is about 70hp, about as much power as a std ford escort makes. You can get figures from many people that also have flywheel vs rwkw and take a average. |
07-12-2013, 03:53 PM | #17 | ||
PM CAT600, I recall a post he made about this related to drivetrain loss and what he'd seen a V8SC pull on a dyno vs what one had run at the strip
07-12-2013, 04:10 PM | #18 | ||
4 users like this post: |
07-12-2013, 11:00 PM | #19 | ||
335 kw of goodness
Sorry a balls up on my part between HP & KW
I was meaning most cars lose 25kw drive train loss.. We have done the percentage thing a thousand times & it doesn't work.
07-12-2013, 11:08 PM | #20 | ||
A big vehicle with lots of torque and big bearings drive shafts and gears is going to need a lot more power to turn wheels compared to vw or an escort.
08-12-2013, 12:27 AM | #21 | |||
What else has changed since I did Mechanical Engineering at UNSW? |
08-12-2013, 10:09 AM | #23 | ||
335 kw of goodness
If what I say bothers you so much, why reply?
08-12-2013, 10:32 AM | #24 | ||
Thailand Specials
If the rule is 20% for RWD cars, what about for FWD cars as they are more efficient at getting their power to the wheels?
08-12-2013, 11:42 AM | #25 | ||
08-12-2013, 11:48 AM | #26 | ||
I read a year or more ago in a Motor magazine that they put down about 620hp at the wheels. Going off about 650 at tje flywheel, that's only a 5% loss. Given the tech that goes into a racing transmission and diff, I figured this value to be reasonable.
I work in transmission design and development and have seen efficiency curves for transmissions. Generally, for a particular transmission, the higher the input torque the higher the efficiency. This is because there are losses in the transmission that are not closely related to input torque- as it rises significantly, the losses may rise slightly or remain constant. The peak transmission efficiencies I saw in those curves were around the 95% mark. Hypoid type diffs suck a reasonably large amount of power- the axis of the pinion does not intersect the axis of the crown wheel. This necessitates a tooth design which results in sliding contact, as well as rolling contact. Normal gears have rolling contact only, so their mechanical efficiency is very high- on the order of 97-98%. Hypoid bevel gears have a mechanical efficiency of 92%. So if it was done right (and I'm certain it is!) a driveline loss on the order of 5-10% in a racing car is not unreasonable. |
08-12-2013, 03:26 PM | #28 | ||
Peter Car
It would come as no surprise to me if V8SC teams spent a fair bit of time and money making the drivelines as efficient as possible by reducing friction etc. Any reduction in friction is going to make a car faster, and with a parity formula such as V8SC, these sorts of gains would have to be looked at.
08-12-2013, 04:37 PM | #29 | ||
I miss my wheelbarrow
Old 595hp engine showed 500 even at the wheels years ago when dropped in the car... 95 hp loss and of that probably likely only 20-30 in the trans most of it in the 9" for all the reasons Madmelon listed above (tooth contact in that style of diff)
Daniel |
3 users like this post: |
08-12-2013, 05:51 PM | #30 | ||
