Jim
Seen it used on Wheeler Dealers on pay TV...
Not cheap tho... Ed just took the radiator cap off when the car was at normal temp... That's the only time I have seen it used.
The Daily. White 2017 ZG Escape TDCI AWD Wagon The Wifes. Grey 2015 MD Mondeo TCDI Hatch The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread |
you really should google it i did and seen some info on other forums that pointed out some things about it that don't work!!!
like how hot this stuff can get with out it letting you know!!!! it wont over flow and let you see steam like water will, so if your not looking at the temp (like you should) the engine has the chance to run way hotter then it was designed to some part of a motor are not designed to run that hot.....like eb-el 6cy heads lol but check it out
GIMME FUEL, GIMME FIRE, GIMME THAT WHICH I DESIRE. ---------------------------------------------------------------- BA falcon XT mkII, 5.4lt, 5sp, Y-code, xy windowless pano, 3 on the tree manual. re-shelled xy falcon GT, manual. 1980 honda CX500 scrambler/dirt tracker |
3 users like this post: |
Cowboy
I did a lot of research on it and was all keen to give it a go until I found out the price.
1927 Pontiac tourer 1928 Pontiac tourer 1929 Pontiac sedan 1930 Pontiac Landaulet 1932 Pontiac V8 sedan 1935 Pontiac sedan 1937 Pontiac 8 sedan 1948 Pontiac silver streak 1949 Ford F3 pickup 1953 Pontiac Chieftain 1955 Austin Champ 1957 Dodge Power Wagon 1967 Jeep Gladiator 1975 TD Cortina 1978 F100 4x4 2006 GU Patrol ute |
#5 | |||
![]() ![]() Join Date: Jun 2006
And I question also the long term effects on water pump seals etc which weren't designed for this coolant. Probably ok, but for sure? |
What is a rough price guide? I have never been able to get my Mustang to run at an even temp.
I have a dealer about 15 mins away so might go investigate. |
I saw the wheeler dealer episode where Ed China put this stuff in a triumph TR6.
I agreed with the benefits which he stated as being no water which meant no corrosion, and no pressure which took the stress off tanks and cooling system components. Either way...... It really seemed to have its benefits. With regard to purging the water out of a cooling system, would a vacuum pump work? |
if i remember he said it took 3 or 4 days to remove all the water from the system to do it properly. And he used some sort of liquid to suck all of the moisture out of the system.
snake oil
7 users like this post: |
Brad
Waste of money I just drop my anti freeze every 3 years. What happens if you car needs repairs and risk of the expensive fluid getting contaminated.
Fluid would be fine for trailer queen but not a daily. |
#12 | ||
![]() Join Date: Oct 2006
Both the cooling system books I have recommend it Engine Cooling Systems HP Books 2007 Ray T Bohacz and Automatic Cooling System Basics Krause publications 1999 Rand Rundle as have various other US based mags I get. Nonetheless, I have never considered it worth the cost for any of my cars. If I had something rare and not often driven I'd probably go for it. I just use Castrol Coolant and change it all every 2 years.
regards Blue |
Jay Leno likes it: http://www.youtube.com/watch?v=t7PykrgzWPQ and http://www.youtube.com/watch?v=KRLXKW2ph0w
regards Blue Last edited by aussiblue; 22-10-2013 at 07:34 PM. |
#14 | ||
Liquid Intelligence 115 High Temperature Super Waterless Coolant appears to be an Oz alternative and I think available from site sponsor Mainlube. http://liquidintelligence115.com.au/...TELLIGENCE_239
regards Blue |
#15 | ||
In the topic of changing the coolant every two years, you can buy test sticks made by Castrol (sold at Repco) which you can dip in the coolant to see if it still has adequate alkaline protection or not. They give a range of outcomes, eg. good, intermediate, bad, so you have a reasonable idea where it's at. Only downside is that a pack of fifty costs about $30. But I suppose the upside is that if your coolant still had excellent protection at 2 years you might hold out for another year before changing it.
I'm not advising anyone to do this next bit, but when my glycol coolant (50 + % glycol) did start to lose a bit of alkalinity I just threw in 250 mls of coolant concentrate (green) as you would use with water based coolant in old cars - brought it back to nice and alkaline so I might be right for another year or so :-) |
#16 | ||
Brad
We refractometer for testing the antifreeze protection. When I got my car antifreeze protection level was fine but when drained radiator and sent away to be flushed it was over 35% blocked, which isnt bad but still.
#17 | |||
regards Blue Last edited by aussiblue; 23-10-2013 at 04:31 PM. |
#18 | ||
MY21.5 Mustang GT
I don't see how? It has a number of quite obvious benefits.
#19 | ||
#20 | ||
How is it a toss?
I would think that is what everyone would have been saying when fully synthetic oil came onto the market. |
#21 | |||
#22 | ||
I see they have an Aussie website now http://www.evanscoolants.com.au/technical and if it is "snake oil" the ACCC and motoring clubs will soon be on to them.
regards Blue |
#23 | |||
There are some interesting debates http://forums.aaca.org/f169/waterles...ce-309949.html
This is also interesting: http://www.norosion.com/evanstest.htm Quote:
regards Blue |
2 users like this post: |
#24 | |||
regards Blue |
#25 | ||
Yeah, I'd like to see first hand more people using any new product for a while first and confirm it works, before I'll think about using it in my car.
#26 | ||
Cowboy
I've spoken to a number of people using with great success.
#27 | ||
Some further debate here http://www.v8registerdata.net/viewre...&topicid=11514 re it being combustible but not flammable.
regards Blue |
#28 | ||
I might try it in my 1963 EH Panel Van - there's not to much that will burn in that anyway.
regards Blue |
#29 | |||
Hmm they Evans have considered the viscosity issue:
regards Blue |
#30 | ||
So it seems unless I own a pre WW2 rocket...
I would be largely inconvenienced and no benefit for the privelidge of running such snake juice. yea nup |
