Old 05-07-2013, 09:56 AM   #1
glennn
Default telstar harmonic pully
hi, im new to this forum but im a little bit stumped, i have replaced the head gasket and i had to unbolt the 2 cam shafts because they were sligtly in the way when torqueing up head im 99 percent its back properly after marking camshaft to timeing belt and rotor position , but i cant get it to start i did notice the timing mark on the harmonic pully is out about 90 degrees , there fore i cant get the timing exact, if it is what affect will that have on trying to start the engine, beside the water pump and alternator is there a sensor thats needs the pully to be in right position , i know of the crank shaft sensor behind and hidden but thats is only for injectors mainly , so even if it was taken off ,you could still be able to start engine , is this right, "engine will star with out harmonic pull" what do you reckon, i had to do this all in the first place because the engine" 4 cylinder " 2 litre just stopped when hit high temp red mark? thanks
glennn is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2013, 03:27 PM   #2
OCTANEBOSS
Default Re: telstar harmonic pully
Try the mazda forums. I googled a timing belt change for the 1.8l BP laser motor and managed to get pdf file that goes step by step and show all the timing marks..
OCTANEBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2013, 04:50 PM   #3
glennn
ok thanks for that, j have now got it going, my cams which I had to take of to torque up head was a couple of teeth out on timeing belt,near enough was not good enough. thanks
