I've just taken delivery of my MC TDCi Mondeo Titanium Diesel. Loving it. As a new comer to Diesels I have a couple of questions.
1. Any difference between truck and normal Diesel, other than advertising Hype? 2. The adapter that comes with the car for the Diesel, has anybody used this without a problem to fill up from a bowser that has the larger nozzle for trucks? ie doesn't spray you with Diesel. (Or is the adapter only so you can fill from a Jerry can). 3. If you can't use the supplied adapter, is there anything aftermarket I can use? I'm off to Adelaide next month and don't want to discover that all the country bowsers are the Truck Type only nozzles. 4. Can I use Bio Diesel? |
Mark,
My answers in red. 1. Any difference between truck and normal Diesel, other than advertising Hype? The only different "types" of diesel in OZ are alpine blend and summer blend which are used in the higher and colder areas during winter. Different brands might use different additives to help reduce algae etc. but I don't reckon you could go wrong if you stick to the main brands - Shell, BP and Caltex. I only use BP cause I prefer their diesel (seems to run better in my D4D Hilux nothing factually based just my perception after running it on Shell for a year or so) so that is the fuel card I got. 2. The adapter that comes with the car for the Diesel, has anybody used this without a problem to fill up from a bowser that has the larger nozzle for trucks? ie doesn't spray you with Diesel. (Or is the adapter only so you can fill from a Jerry can). The adaptor is to be used with the high flow bowsers that truck and some country stations have for diesel, I have used it and it dropped fuel out of overflow pipe in the wheel arch, but mine drops diesel on the ground when using a normal bowser so best not to use my experience as gospel. 3. If you can't use the supplied adapter, is there anything aftermarket I can use? I'm off to Adelaide next month and don't want to discover that all the country bowsers are the Truck Type only nozzles. Use the supplied adaptor, you wont need anything else. 4. Can I use Bio Diesel? I wouldn't use bio fuel in my car, but check with Ford and ask them if you really want to use it. |
Last edited by Menai Mark; 15-03-2011 at 04:28 PM. Reason: Meant to be a new post |
Batman105E - Awesome. Thanks for the quick replies to my questions - much appreciated. Not so concerned about Bio Fuel specifically, just more curious, as I'm sure this will become more widely available in future.
Biofuel will void your warranty...check your manual/handbook.
I run a 2.0 TDCI Focus and BP Ultimate diesel gives better economy 5.2 v 5.4 ltrs per 100kms but costs more! |
Giddy up!
I've used the adapter many times, and it's tricky to get it to work just right. It won't click off sometimes, and spills diesel.
I use it as a last resort. I've never figured out how to use it, and I also find the 'car' pumps to be cleaner, and closer to the shop!
Current: June 11 built Titanium TDCi Territory, Edge, side steps, mud spats, bonnet protector, tow pack, full tint. Nov 10 built XR6 Sensation. Previous: Oct 07 built Mondeo TDCi hatch, Stardust Silver, bluetooth, leather, tow pack, sunroof. |
#7 | |||
apstar |
#8 | |||
In regards to the Mondeo TDCi engine: Does Sulphur level have an impact on: 1. engine were and tear 2. performance 3. economy? Do I: 3. avoid using truck diesel at all costs 4. ok to use now and then 5. it doesn't really matter and can use it as often as I like? Just need to know as I'm new to diesels. Thanks in advance. |
#9 | |||
Giddy up!
I can remember when diesel was only used by trucks and hard core 4wds. Not any more.
Many women now drive diesels (I've been called this), and if my partner is anything to go by, won't be fiddling around with adaptors and trying to use a high flow pump. It's good that the petrol companies realise this and offer more user friendly options for diesel owners. Having said that, my partner has never filled up my car, that's my job (apparently).
#11 | |||
Shell Diesel Extra Shell make a Diesel Extra that is wholesaled to mining and transport companies and not available retail as far as I can gather but is also low sulphur BP BP Ultimate BP also make BP Ultimate which is not available everywhere yet, they also make 5% bio Diesel available in NSW and also mention the winter blend, all these are also low Sulphur. Caltex Caltex make mention of only the Vortex Diesel, which is also low sulphur. |
#12 | |||
Mondeo MD Titanium Hatch
Where is the adapter stored? I haven't found it yet? Did the dealer point it out? Cheers Mark 7
Mondeo Titanium Hatch TDCI Ruby Red-MD 2016(MY17) Territory TS RWD Ego. |
#13 | |||
Batman105E response is spot on I use BP Ultimate and carry it with me if I know I am going somewhere where there is no supply There were cases where Sulphur was desirable for lubrication purposes especially with fuel pumps in fuel tanks and indeed additives were added to the low sulphur diesel but thats now been incorporated into the fuel apstar |
#14 | |||
#15 | |||
apstar |
#16 | |||
Giddy up!
#17 | |||
Thanks for your help everyone. Cheers Mark 7
#18 | ||
As some of the others have already said all diesel sold in Australia since 2009 is low sulphur its the law. Like petrol some suppliers will claim their product has additives that make it better than their competitors. The main difference is there are alpine blends available to stop it freezing in subzero conditions but I'm not sure if that's available at retail outlets, I have it delivered a few 1000L at a time during the colder months for use in machinery. Bottom line its like petrol in that you can get a bad tank from a dodgy outlet but otherwise don't stress too much about where you buy it I would be more worried about the fast flow nozzle than the actual brand.
#19 | ||
Do you have BP Ultimate diesel in Oz? We have it here but there is no price premium as in the UK, so I suspect it's just a marketing exercise.
#20 | ||
Why would you refuel anywhere other than in a metropolitan area - if that's where you live? All metro stations have car pumps - if they have a high volume (truck) pump - it's out the back somewhere.
The cetane rating of different diesels can vary a little - but I understand the sulphur level is identical for all brands! |
#21 | ||
The sulphur content is measured in ppm normal diesel prior to 2000 had something like 5,000ppm then it was reduced to 50ppm now its around 10ppm because of the low sulphur content seals were being effected especially fuel pumps so a lot of work has been put in by car manufactures to design pumps that prevent seals from cracking and engine components
apstar |
#22 | ||
Same in NZ - 10 ppm. It has to be this low so that diesels can meet the latest emissions standards such as Euro V. For some years we couldn't buy Euro diesels here because there was too much sulphur in the diesel. And despite all the prophets of doom, the roadside is not littered with broken diesel vehicles that couldn't run on low sulphur diesel.
#23 | ||
[QUOTE=obione980]Why would you refuel anywhere other than in a metropolitan area - if that's where you live? All metro stations have car pumps - if they have a high volume (truck) pump - it's out the back somewhere.QUOTE]
Well actually no. I pulled into a Mobil service station in Kirawee in Sutherland, Sydney south - all they had was a Hi Flow Truck Bowser (x2). Definitely a Metro station and definitely not a Truck Stop type service station. Went to another servo down the road so no probs. I've also pulled into a BP and on one side was a Truck Bowser, the other a car. |
#24 | |||
Diesel - Winter driving Diesel fuel purchased in the city and coastal regions often has different cold temperature properties than diesel sold in Alpine regions. Wax may form in the vehicle's fuel lines if the vehicle is left outside overnight or for a number of hours in below zero temperatures. This means that the vehicle will not start or run correctly until the wax has melted. To avoid this problem, if a prolonged or overnight stay is planned in an alpine region then it is strongly recommended that the vehicle carry enough fuel to get to the Alpine region and is then refuelled locally so that at least 50% of the fuel volume is Alpine mix diesel. At the time of publication, Alpine mix diesel is available at the following BP service stations: Victoria Bright, Corryong and Mansfield NSW Jindabyne, Thredbo, Tumut, Talbingo, Adaminaby and Cooma. Please confirm availability at the time of your trip. (End of what is stated in the manual). Important for us skiers / snowboarders to know this! Anybody had experience with diesels not starting or not running correctly in cold weather? What did you do / what happened? Please share your experiences. Thanks. |
#25 | ||
I had a situation where the fuel nozzle on the only pump (it wasn't hi flow - suburban Sydney) wouldn't make the valve in the filler open. The only way I could get fuel in the car was to use the hi flow adapter to open the valve and use the pump normally.
Also, I dont think you would want to store the adapter in the glove box unless you were able to wipe it perfectly clean. One thing I didn't realise about the diesel - it can be a bit messy. |
#26 | |||
#27 | |||
