I have done a search and cant find exactly what i'm after which is tips on removing the whole AU dash.
any help appreciated thanx. |
Do you really mean the whole dash? It's just that I've heard so many people refer to the centre section (radio, A/C fascia) as the "whole dash". Which of course it isn't. LOL.
Is your car a Falcon or Fairmont? |
Flairs - Truckers Delight
tip: get a philips head screwdriver and go to town
the whole shebang needs to come out! its only a miserly forte ;).........i know the centre section has to come out, i'm looking for a sequence of what to remove with least damage inflicted.
thanx. |
its not that hard...... but pretty labour intensive, i had another car to drive so i took my time and some items that could be a question mark on reasembly i put labels on, even cable tieing some cables wires in pozzy so i could locate them easier afterwards,
battery disconnect, glove box remove, passenger air bag cover and air bag, t`bar,console,radio, heater controls, dash gauges, once dash gauges are out it gives room to unclip some other buttons/controls behind the dash, front seats to give more room, kick panels assossiated plugs, steering column cover and plugs + bolts top and bottom....bottom from the rack end first iirc, pretty sure i took the steering wheel off to give me more room.......i`m not sure that was needed, unbolt unclip fuse box, big loom connectors, clip in access panels to the dash left and right .....you`ll see them when you open the door exposeing 2 bolts each side, a panel on top of the dash with 3 screws .....i think.....once removed shows some bolts holding the top of the dash, the green bolt is the earth, i`m not sure thats correct sequence but thats roughly how i did mine, someone might be able to correct any fo pars i`ve made or add what i missed, good luck. |
What about just removing the climate control/range cluster on the fairlane/fairmont.
i had a go with a screw driver a few weeks back, couldnt lever the thing out. :/ That or i just wasnt trying hard enough. Any opinions? |
#7 | |||
thanks mik for the above post it helped heaps. ![]() |
#8 | |||
AU Falcon Man
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 |
#9 | |||
FORD AU FairGHia 2000 Removing Dash to replace cabin filter ? Any help ? or should i just start cutting til i strike gold? cheers.
#11 | |||
You can't stop the signal
No cabin filter in AU's
#12 | ||
Yeah. the evaporator gets full of lint fluff etc, blocking air flow. be nice if you could block the vents and just blow it all out again LOL
wrecked my au2 fairyG got a forte, so now the fairy is stripped to build up my au3 forte
