Old 17-08-2010, 06:52 PM   #1
Pis-ton broke
Pis-ton broke's Avatar
Default f150 jump start and computer games
Hi, advise is needed in regards jump starting and the possible effects on the computer?
Well the short story is; my neiughbour sends truck (89 F150) to machanic to fix it for a fuel pump problem. Gets truck back, it goes, but is using petrol like there,s no tomorrow. Sends truck to a different guy, he said the trucks been jump started wiith straight leads, that is with on surge protector, he said the computers stuffed. Theres $500+.
First question; Is this true. can a jump start stuff a computer?
Q 2. If its stuffed, why can,t it just be rebooted?
Thanks for any help.
Mick
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2010, 07:20 PM   #2
Nikked
Oo\===/oO
Nikked's Avatar
Yes, a spike in electricity can cause problems with your ECU
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2010, 08:05 PM   #3
Interceptor
HSV - I just ate one!
Interceptor's Avatar
1: yes
2: no, because the damage is hardware not software
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2010, 08:31 PM   #4
cedric
q1.i have heard it can harm computer, but have personally seen dozens of cars with computers jumped with normal leads and never heard of problems.
q2.no idea.
there is NO WAY of knowing what caused the computer to die. even if you could pull the computer apart and find the burnt out wireing or component (IF that is even the problem with computer) there is no way of telling what caused it ,it could be faulty battery,wireing or computer. heat,moisture,corrosion anything
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2010, 09:04 PM   #5
macca13
give it a week and see if the computer relearns if the battery was dead flat the computer may have been reset.
macca13 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2010, 09:52 PM   #6
philfree
Hi
yes jump starting can damage the computer but i can't see how it would cause this problem i would expect it to just not start at all afterwards. But take the battery terminal off for 10mins and put back on and try it for a week just to refresh the memory of the computer
philfree is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2010, 09:17 AM   #7
MO
MO's Avatar
When jump starting modern cars you MUST connect the neg/earth lead to the motor,otherwise there is a chance of causing a spike.
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
