rexnet
i need an exploded view for the manual in my car.
its changer is kinda sloppy and i think its a bush or something thats worn out. also. excuse my dumbness. its a T5 manual yes? |
yes its a t5 manual
i had a bit of a look in a transmission book for a t5 diagram was`nt much there, , but its a common tranny used by ford gm,jeep etc, there are snippets on google , look up borg warner t5 i think , you might find something, there is a couple of pages of a rebuild magazine in a ford mag unless your a subscriber you get the first 2 pages only theres a little bit of the shifter........click on the smaller pics
http://www.google.com.au/imgres?imgu...N46TkAW62uzjBw |
rexnet
thanks guys. basically i just want to pull the gear leaver off from the top and hope that there is bush i can acess from the top and replace to fix the sloppiness. not made keen on dropping the trans for a grommit
should put a short shifter in if u havent already done so
Well i can tell you there is a bush in there and the shifter has lots of slop when it is buggered. Here are some pics of the buggered bush.
I had this gearbox and the one now in my car next to each other a while ago and this bush is definately the reason. ![]() ![]() ![]() ![]() ![]() Cheers, Rhys
Toy Car Build |
rexnet
A. what does a short shift actually do (yes im dumb)
B thanks so much rhys. guess its a gear box out job then? |
Makes the shift between 2nd and 3rd alot easier,
Pretty sure it would be easier with the box out but it may be able to be done by simply removing the centre console. Then just support the rear of the box and lower it slowly by removing the rear cross brace from underneath. This may give you enough room to get through from the top to do it. However without having tried this i can't be too sure.
As for a short shifter effectively it shortens the throw between all gears and with a better return spring enable more 'Positive' shifts between gears. This would be most noticeable through the 2-3 shift as this is the worst out of them to start with. However, i have never actually used one so someone who has will be able to tell you more accurately if it is worth it. A short shifter replaces the top section which unbolts. It also includes the section on the very left of picture 2. This is the mechanism that allows (through different angles) to give it a shorter throw. Cheers, Rhys
Toy Car Build |
i think i`d rather drop the x member and remove the console than pull the box out if neccassary than pull the box out , does any one have a pic of an au gearbox/tranny tunnel without the console carpet etc?
I will go take one now! Give us a couple of mins
Ok this is it. First photo is with the gear lever and surround. This can be removed by taking off the gear lever and then from underneath there are 4 nuts holding the white plastic thing on. ![]() Then this is what it will look like ![]() Cheers, Rhys
Toy Car Build Last edited by bartsau; 16-05-2010 at 06:35 PM. |
#12 | ||
rexnet
im thinking droping the box will be easier. and i can kinda get to a hoist easily. it just wont happen for a while
Good luck with it when you do it. Let us know how it goes to...
Cheers, Rhys
Toy Car Build |
#14 | ||
Hey guys i had the same problem with mine but the part i got is only the plastic bush where the one that was in there had a rubber coat over it over it just wondering if its a seperaye piece or what to do ???
BLACK AU II MANUAL XR6 UTE 2.5 inch Redback Exhaust Pioneer 6050 2 din unit Pacemaker 4499s Custom CAI |
#15 | |||
The rubber section is part of the shifter block itself as it is molded into it. This from ford is worth about $160 from memory whereas the plastic bush is the only separate part you can change apart from the block and the plastic bit is worth about $23?? Hope this helps. Cheers, Rhys
Toy Car Build |
#16 | ||
Ohh okk well when i pulled out the bush the rubber was pretty stuck to the bush itself .. The rubber didnt stay in the block .. Could i just fiill around the bush with some sort of silicone application?? The bush fits in well without the rubner ..
#17 | ||
ROCKING THE EL FUTURA
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
#18 | |||
Not too sure if you can get away with that? I will be pulling mine apart tomorrow so I will have another look as it is a while since I have had a good look at it. Also, I know you can order from the US brass bushes to replace the plastic ones. However, they apparently transmit more vibration and I would think would wear the rubber out quicker.
Toy Car Build |
#19 | ||
Well the rubber is stuck to the other plastic bush which has broken in half.. Could pull it off the original bush but dont no if thatll work ..
#20 | ||
#21 | ||
rexnet
5/8th heater hose is holding mine firm at the mo. Hahaha
#22 | ||
Yeh ? How long have yu had it in there ? Might give that a go ...
#23 | ||
rexnet
Ahhh. September. Only because I needed my car back togetherthat day and I didn't have the$$$ to get the replacement.
It's starting to get loose I'd suggest doing it right. |
#24 | ||
Yeh .. So whats the part i need to order to fix it properlly ..? Whats it actually called ? Ha
#25 | ||
Was reading around and see some people say yu can leave the rubber bush out and it will feel firnmer should i give this a go ???
#26 | ||
While I had a look at it tonight and have come to the conclusion that there is no way the plastic bush is coming out without damaging the rubber as they have become one over time and use. Not entirely sure how I am meant to use the plastic bush I have now though :/
Toy Car Build |
#27 | |||
rexnet
#28 | ||
fixed mine up this morning with 5/8 heater hose and some glue. feels amazing to what it did. lets just hope it lasts !!
