Old 03-12-2009, 02:01 PM   #1
shano_falconoot
Default 1.6 KC Laser Timing
G'day all,
I got a mate with a KC laser with the 1.6 carby enigine, which is running bit rough, I want to check the timing but am unsure of where it is meant to be set, it also idles up a bit high i feel on the choke, (higher than i think it should) is there an adjustment for the auto choke on it
shano_falconoot is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2009, 05:16 PM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Timing according to my Relim chart is 2 degrees BTDC +/- 1 Deg with the vacuum hose disconnected. Idle speed should be 800-900 for the manual and 900-1050 for the auto.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
