hi i was just wondering if anyone has had this problem, the auto in my au1 is leaking from the back of the sump, i've taken it to my mechanic and he's cleaned around the area and tightened the bolts on the sump, but it's still leaking, doesn't look like is coming from the rear tail shaft seal as there's no oil around it. but he said it could be coming from the breather at the top, it only leaks when i turn the car off and it sits for a few-minutes then it oil starts dripping but only for a little bit then stops, im going to take it back to my mechanics tomorrow so he can look at it.
cheers
Daily: UA11 BiTurbo Everest Weekend Project 1999 AU XR8 Past rides: Mondeo XR5 Turbo RIP: FGX XR8 MANUAL Build Thread: http://fordforums.com.au/showthread.php?t=11447239 AU Fairlane Sparkling Burgundy thread: http://fordforums.com.au/showthread....61#post5854961 UX explorer limited FOCUS ST, UT Explorer limited Written OFF BA XR8 Build Thread: http://fordforums.com.au/showthread....1299363&page=7 AU XR6 VCT ED GLI Classic |
BA Xr8
Ive had a leak from the auto pan gasket before which was a simple & cheap replace.
Ford beginner
I had a very similar problem. Turned out to be cracked/broken seals. Replace the cheap rubber ones with some copper ones. It's a good start at least.
#4 | |||
Irregular member
I had the same problem, turned out to be a gasket that needed replacing.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
#6 | ||||
Back to Le Frenchy
Irregular member
RG, I think this is exactly what happened with mine. The mechanic struggled for ages to undo the bolts and said that Superman must have done them up. He was having a really hard time. A reputable Ford dealer may have done it.
just got back from my mechanics, turns out it was the oring around the servo was stuffed so its been replaced and hopefully that fixes the problem
you can straighten the pan rails while its resting on a block of wood or something similar out, usually a few hits with the persuader will do it, never found a metal one that could`nt be fixed.
