Old 30-06-2007, 01:44 PM   #1
gthofan
Gunna girlie-man
gthofan's Avatar
Default Its never easy... Motor stuffed.:(
Hey guys, recently i have installed an xr6 head to my 300,000km old engine. Simple enough, but 2 days later starts blowing blue oil smoke when cold, so i went to the mechanic and he said hopefully valve stem seals. I had those fixed on wednesday, but its still doing it. So it leaves one thing it could be. The piston rings.
It seems that e-series cars and me are just not meant to be... I need some advice on what to do,
1. Complete auto v8 conversion for about $1200
2. Au engine conversion using my xr head and rocker gear/cam $cost unknown
3. Save up and buy a new short motor for about $1500-$1700
I just dont know what to do, after having the ea die on me, and now this car, im about to lose the plot i think :(
any suggestions??
cheers
scott
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 01:48 PM   #2
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Hey Scott bad luck there mate. I'd say so the AU conversion and put your XR head and cam gear on it. You could just use MPFI to make the conversion easier. Theres a few members on here who would be willing to give you a hand I'm sure.
A V8 conversion would be nice but I'm sure theres a lot more stuffing around.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 01:58 PM   #3
gthofan
Gunna girlie-man
gthofan's Avatar
Im not too sure of the cost of an au engine, Would i have to do a serpentine conversion?
Old 30-06-2007, 02:11 PM   #4
twincamfalcon
You can mess around and not run the serpentine conversion but you may as well IMO.
Could put a BA motor in there as well. That would be sweet.
I think Sundeep knows all the ins and outs with a V8 conversion, he helped a guy I know get his running. That is what I would be doing. You can beat that sound for a daily driver IMO.
twincamfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 02:17 PM   #5
Dezza
Parts bin special
Dezza's Avatar
Bad luck Scotty. I reckon go the AU engine. If you do that, at least you'll be able to keep your manual too.
Old 30-06-2007, 02:20 PM   #6
gthofan
Gunna girlie-man
gthofan's Avatar
i saw recently that ba twin cam motors go for about $600 on ebay. but i would have no idea on how to set up twin cam.
Old 30-06-2007, 02:21 PM   #7
snypereb
[EBGLT]
snypereb's Avatar
AU motor should come with serp scotty get the bloddy head reco'd. that should do the trick! AU motor from FTG Auto Salvage I think are $600 - $800. Dont quote me on price though. Talk to Pat pretty sure he did his AU Engine conversion for a $1000. I think he is banned on here at the moment though?
[EBGLT]
Old 30-06-2007, 02:33 PM   #8
trick_xd
I build your wish list...
trick_xd's Avatar
gthofan
give me the motor and a good cam and I will rebuild it for you ... a good solid rebuild 2k
it will be stronger then a AU motor
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 02:34 PM   #9
mcflux
mcflux's Avatar
chat with Yagz or Pat if you're considering an AU swap ;)
Old 30-06-2007, 02:40 PM   #10
snypereb
[EBGLT]
snypereb's Avatar
Originally Posted by trick_xd
gthofan
13.77 quarter mile NA on gas scotty this is the guy you want to talk to!!!!
[EBGLT]
Old 30-06-2007, 06:24 PM   #11
trick_xd
trick_xd's Avatar
yep but my motor is a far bit more then a 2k rebuild .. my block , rods , head and inlet manifold is over 2k by it self.
if the rest of your car is up to it I will get you a 14.7 to a 15.4 qtr
I have built another motor running in a EB in melb that does 15.3 with crow cam 3.23ss diff manual and cat back .. thats all
as your at wade im sure you would be able to "tweak" a better cam for your self to use..
Old 30-06-2007, 06:33 PM   #12
Sundeep
Sundeep's Avatar
Know how you feel.
Did a head gasket for Rips' Mum's car the other day and some git who was helping decided to muck (I wanna say so bad muck doesn't have the same affect but pretend I said there ok) with the tensioner and broke it. Long story short the motor was put back together and promptly welded the dizzy shaft after about 10 minutes.
Ordered a new motor the next day ($500 EL job, delivered to the door from Ozwreck). It didn't look too spectacular when it arrived but 3 good people working on it, good tools/air tools and 9 hours saw it all fitted (dual fuel too!) and running well first turn of the key.
Borrowed a crane off Dan too, so that saved about $50. Dansedgli for unban.
Soooo yeah. Don't waste your time just jam in a ED Tickford 4L FTW. Engine changes when you install the correct motor for the car are way less around.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 06:35 PM   #13
-jjM-
-jjM-'s Avatar
got a Tickford Motor sittin here for you if you want it scotty ;) chat to me on msn man
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 07:00 PM   #14
Tiga_EL
Tiga_EL's Avatar
too many burnouts for u eh scotty... shame shame shame
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 07:22 PM   #15
[T1PTOP]
300,000 Dam! your car must be taxi spec haha
[T1PTOP] is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 08:20 PM   #16
MADED-6
MADED.6
MADED-6's Avatar
yeah go the au motor man a shuresm on here got one for $550 i think it was have a look at his thread..
have a look around and see wat u can find.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 09:07 PM   #17
private9
www.TUFFCARPARTS.com
private9's Avatar
If you're going the rebuild route, I'd be giving Trick_XD a yell. He knows his stuff (just look at his times) and is a great guy. If not going rebuild, I'd be thinking AU conversion.
Old 30-06-2007, 09:42 PM   #18
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Bundoora Auto wreckers will have AU motors for $500 including all accessories. Just tell em a few of your mates with earlier model cars had picked them up for that price before.. They'll look after ya. It's easy to install.. Once you have the XH tensioner ($80 from bursons) and an EF/EL A/C compressor, the rest is easy.
Good luck.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 10:35 PM   #19
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
AU engine!!! AU engine!!! AU engine!!!
oh and a turbo while your at it!!
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 10:58 PM   #20
trick_xd
trick_xd's Avatar
you don't need to run a Air-Compressor now there is a off the shelf part that you can buy from ford for 55$ and it will bolt where your Air-Con goes and its just a idler pulley .
Old 30-06-2007, 10:59 PM   #21
Christiaan
Christiaan's Avatar
yeah.. or you could grab an a/c from a wrecker for that price and get it regassed for when summer comes around ;)
Old 01-07-2007, 12:38 AM   #22
The Goodz
E-Series Firemaker
The Goodz's Avatar
If you wanna get out of it cheaply I have an EA bottom end you can have for $50...
Alex
Automotive photography, fine art landscapes, portraiture
Photo retouching and restoration
The Goodz is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 01:02 PM   #23
Molloy
Captain beat down
Molloy's Avatar
AU engine would be the go, very cheap to pick up
Molloy is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 01:09 PM   #24
twincamfalcon
Any idea if they have these for BA motors as well?
A rebuilt stocker would be more reliable that an AU conversion IMO. I dont know any AU's that are low km's any more. Even an early BA motor would start to have high kms.
If you get the engine rebuilt then you shouldnt have to worry about it for another 300,000kms.
Just get the short motor done and it shouldnt cost too much. It will cost more than an AU conversion but "should" last longer than a wreckers special engine that you dont know the history of.
It would be less stuffing around and will be legal unlike a BA conversion and you wont be cursed with pushrods. Those EFI windsors are the ugliest motors ever, I wouldnt want one of them in my engine bay.
Old 01-07-2007, 03:16 PM   #25
trick_xd
trick_xd's Avatar
No Idea about BA motors.
I just know they are there for E-series as I have spun 3 Air- Con bearings over the last 18 mths .... So I was going to make something for my motor ... and then ford told me there is a part already made as they have found that the Air-Con pumps are not all that good when you over Rev your motor or stay at mid to high revs for long times..
If it weren’t for physics and the law enforcement, I’d be unstoppable.
Old 01-07-2007, 04:24 PM   #26
gthofan
Gunna girlie-man
gthofan's Avatar
Good luck.
just a few questions on the au motor. Can i still use my manual gearbox? will it all bolt straight on? How hard is it to modify the sump? and what accessories does that come with?
cheers
Old 01-07-2007, 04:42 PM   #27
Kenaz
Kenaz's Avatar
With help from the mad scientist you should rip apart the block and replace the piston rings you fried.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 04:47 PM   #28
bentles
bentles's Avatar
easily the best fast and furious reference ive heard yet.
bentles is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 05:32 PM   #29
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
hard luck scotty... hope u get it sorted soon
+1 for AU dependant on cost.... next choice is add 2 cylinders ;)
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 06:00 PM   #30
[T1PTOP]
why??
so he can go just as slow as a i6 but use more fuel.
yer do that.
