Old 16-09-2024, 02:01 PM   #1
dtholz
Default Swamped ranger
Got a little water in px3 on weekend on pass side , electronics started playing up after that steering , hill assist , cruise control , ESC , pulled seat our and found a modual on floor , xmckeaned and dried it , my question can this be the cause and what it called if I need to source another
dtholz is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2024, 08:05 PM   #2
swamp
Default Re: Swamped ranger
hi
Water ingress can fry electronics today and in the future . The future problems can be caused by moisture or developed corrosion over time . If your unlucky modules that are wired to the wet unit may fail in the future also .
The wiring because companies use the smallest possible size can fail as moisture wicks itself up the cable from connector and corrodes wires internally . The signal or power flowing thru can be intermittent .
Obviously the above issues can be difficult to diagnose .
In a simpler car all the dash and engine loom is removed dried and lubed . All ECU are removed and dried . About 7 --10 days work . No guarantee .
swamp is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2024, 08:54 PM   #3
Itsme
Experienced Member
Itsme's Avatar
If it was under the passenger seat, then most likely tow module.
As for your problems, maybe so or maybe not.
Old 17-09-2024, 12:20 PM   #4
simon varley
how and where? Ranger is rated to 800mm deep wading so all the critical electrical joints should be above that.
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2024, 01:14 PM   #5
XR Martin
XR Martin's Avatar
800mm wading, not immersion...
2004 BA wagon RTV project.
XR Martin is online now   Reply With Quote Multi-Quote with this Post
Old 17-09-2024, 03:01 PM   #6
simon varley
well, it's 800mm at <7kmh, so pretty much immersion
Old 18-09-2024, 10:49 AM   #7
Hulsty
No, not its not, you cannot park in 800mm water.
The Silver Bullet - BJ74
Where the actions at Ontrack 4wd Club
https://www.facebook.com/ontrack4wdclub
Hulsty is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2024, 12:52 PM   #8
simon varley
maybe OP can explain a little more?
