Old 20-04-2024, 04:05 PM   #1
Brettnell
Default MC 2014 Mondeo wagon rear drivers side footwell wet
Hi all this is my first post on here.
I’ve been noticing a wet musty smell for a couple of months and it was a soaking wet footwell behind the drivers seat. I’ve since dried it out and checked all the seals and trims on that door but in the last downpour there it all is again. The carpet feels pretty dry the further fwd I go into the front foot well and in the last downpour I got inside the car and looked at the seals all around the passenger rear door and could see no dripping or moist areas. I also checked all along where the carpet runs up and under the plastic trims near the bottom door seal, it felt damp towards the back end but no visible clue how water is getting through from outside. I found no evidence of a leak up under the dash near the pedals and the carpet feels pretty dry there. The cargo floor behind the rear seat also felt dry.
We live in a hilly area so the car parks on a slope with nose and drivers side being the high points (in the downpours yes) so it’s possible the water is coming in further fwd in the drivers area and running downhill but since the carpet up forward is not wet I’m at a loss.
Please help I’m getting tired of vacuuming out water and drying carpet.
Thanks
Brettnell is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2024, 04:12 PM   #2
Brettnell
Default Re: MC 2014 Mondeo wagon rear drivers side footwell wet
I’ve read other threads mentioning leaking from behind the door card but wouldn’t the water be visible coming out the bottom of the door somewhere?
Old 20-04-2024, 06:03 PM   #3
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Does your car have a sunroof?
The problem is where the water is is the lowest point, I had a car that was leaking through at the front pillar but filling the back floor up as it travels under the carpet, you will find if you pull the carpet at the front it will be wet there also.
prktkljokr is online now   Reply With Quote Multi-Quote with this Post
Old 20-04-2024, 08:49 PM   #4
Brettnell
Hi thanks for the response no it has no sunroof.
Old 20-04-2024, 08:51 PM   #5
Brettnell
I guess it’s possible it could be leaking up front but I see no evidence of water coming in anywhere
