13-04-2024, 09:50 PM | #1 | ||
Regular...with metamusal
Evening All.
question today is - when was the Hill Descent control button fitted to the Territory & what model plus what did the "Hill Descent" button control?. have found a Terri with that particular button and it made me wonder about it. Thanks |
14-04-2024, 09:23 AM | #2 | ||
Chairman & Administrator
I believe it became optional on the AWD models from 2007 onwards.
Observatio Facta Rotae
14-04-2024, 06:37 PM | #3 | ||
14-04-2024, 09:12 PM | #4 | ||
ABS system is completely unique I believe.
14-04-2024, 09:40 PM | #5 | ||
14-04-2024, 10:09 PM | #6 | ||
Hill Descent supplies an earth to Pin 36 of the ABS/ESP module. It applies to modules with steering and yaw sensors, so I suppose ESP only…
15-04-2024, 08:32 AM | #8 | ||
15-04-2024, 11:15 AM | #9 | ||
4 users like this post: |
15-04-2024, 05:36 PM | #10 | ||||
well ...... i've just checked out the steering column .. it has the sensor on ze column! not sure if/how i can check for the yaw. Many Thanks for that info ..... i also checked out the blanked switches spot .... has one plug there so i will look closely at the relevant wiring diagrams. Ps. have checked out the wiring loom/Commodorenutt's manuals ...... it 'appears' i have the loom for the hill descent .. Quote:
i presume i will have to pull apart the ABS wiring plug to check for this earth/pin 36 to verify the above then yes?. Last edited by mad2; 15-04-2024 at 06:03 PM. |
15-04-2024, 06:12 PM | #11 | ||
and also .....
while we're at it - how do i test the "hill Descent" button feature out?. do i need to enable anything?. |
15-04-2024, 06:50 PM | #12 | ||
The brake module plug has tiny numbers on the end pins of each row. See if 36 is populated on the harness side and on the actual module.
If so, try buzzing it out from the blanked off switch connector. Good point, your area isn’t exactly mountainous. |
15-04-2024, 08:43 PM | #13 | ||||
great! .. tiny writing..... Quote:
that i can do ........ yeah .. lot's of hills here Ps. i'll have to put the original cluster back in to check as it currently has the cluster from BAFLR6 fitted...... Last edited by mad2; 15-04-2024 at 08:50 PM. |
16-04-2024, 06:09 PM | #14 | ||
tried out the switch .......... without a 'hill' i didn't notice any thing .. no lights etc etc. the original cluster was also refitted with both showing nada.
17-04-2024, 09:30 PM | #15 | ||||
Correct. I had it in my 2004 SX.
Further reading > Enabling Hill Descent Control Cheers, Raptor
. Last edited by Raptor; 18-04-2024 at 02:15 PM. |
22-04-2024, 09:38 PM | #16 | |||
Thanks |
22-04-2024, 10:42 PM | #17 | ||||
so i presume mine is not the one your refering to?? Quote:
where as mine finishes in -AA and doesn't appear to have the HD ?. |
18-05-2024, 12:10 AM | #18 | |||||||
2 users like this post: |
19-05-2024, 10:44 PM | #19 | ||
and the vin
22-05-2024, 05:45 PM | #20 | ||
Yesterday, 08:37 PM | #21 | |||
so should i just unplug the current ABS and plug in the new ABS then?? [without fitting brake lines]. i have forscan so programmings not an issue. should i also 'copy' what forscan has for either ABS modules?. Thanks |
Yesterday, 09:00 PM | #22 | ||
I wouldn’t just plug it in, at least not without disabling the pump power supply. Would be worried it tried to build pressure and either shot residual fluid out at you with risk of skin penetration or damaged the pump by dry running. If that power’s uncoupled you should be able to talk to it with Foreskan.
Yesterday, 10:09 PM | #23 | |||
Thanks Mr. Bender...... didn't think of that part so will do that |
