Old 23-12-2019, 12:33 PM   #1
73 4V XB
Frankenford pilot
73 4V XB's Avatar
Default Posting pictures with postimage.org
Hey guys, this is a small walk through on using https://postimage.org/
I use a IPad for most things and find this to be the simplest way to post images.
You will need to set up a free account. From there you upload from your device to your postimage account. Select the image size, I found “15 inch monitor” a good over all size, then hit the upload tab.
From there your directed to choose a link to copy and paste into your post.
This method will post a single image.
To post multiple images use the following method. Choose the images you want to use, upload to post image and follow the directions below.
Then hit the colum tab to copy and paste into your post.
This method will post multiple images, one under the other.
You can enter text between the images after you copy and paste into your post.
If I’ve forgotten anything please feel free to add your tips.
Hope this helps anyone that’s having trouble or looking for a very easy way to post images. It’s so easy, even a simple panel beater can do it, or even an ol truck driver
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2024, 05:11 PM   #2
gassa
Default Re: Posting pictures with postimage.org
Hi All having problem loading photo for for sale item went to photo image. there driver wants to make changes to my computer. is this common
Gassa
gassa is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2024, 07:58 PM   #3
mad2
Regular...with metamusal
Gassa
doesn't make any changes when i upload pics to postimage.
Old 06-01-2024, 08:14 PM   #4
T3rminator
T3rminator's Avatar
Postimage is a web portal. There are no drivers required. If you downloaded an app, delete it.
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
