20-12-2023, 04:09 PM | #1741 | |||
24V 3V 220 V8 fuel pump in a SWB sedan is the same as a normal 4.0 6cyl, BA9350A, its the turbo and 32V V8 that have a different one. Yes obsolete. |
21-12-2023, 04:29 PM | #1742 | ||
Hi GT
I'm after some genuine fuel injectors for a FG MK2 fpv F6 is this the correct part number for them 8R2Z9F593CA thanks for any help |
21-12-2023, 04:56 PM | #1743 | |||
Correct FG2 F6 injectors had part number 8R2Z9F593CA how ever they are obsolete from Ford. I may be able to track some down for you, but they were around $110 each when available? GT Last edited by GTLEGEND; 21-12-2023 at 05:22 PM. |
21-12-2023, 06:16 PM | #1744 | |||
I've managed to track some down thanks for the conformation Of the part number |
22-12-2023, 03:29 PM | #1745 | ||
Hey gt bit of an odd one, but I’m keen to know. I know there’s heaps of aftermarket alternatives but I wanted to know if Ford still supply front and rear shocks for a 2007 bf mk2 xr6 non turbo. If they do what is the price for said items, otherwise I’ll slap a set of Monroe gt sports in when moneys available, thanks mate
22-12-2023, 04:02 PM | #1746 | ||
Barra Turbo > V8
Looking at a bonnet protector to suit 2011 FG XR6, are the tinted ones still available?
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
22-12-2023, 04:28 PM | #1747 | |||
Unfortunately no longer available.. Cheers, GT |
22-12-2023, 04:31 PM | #1748 | ||
22-12-2023, 05:50 PM | #1749 | ||
Dirty rotten bastard
got a SZ territory thats leaking from the cooling lines on the 6R80 transmission, any idea what size the o-rings are
22-12-2023, 05:58 PM | #1750 | |||
Barra Turbo > V8
What are they worth?
22-12-2023, 06:10 PM | #1751 | ||
22-12-2023, 06:18 PM | #1752 | ||
23-12-2023, 08:13 PM | #1753 | ||
Barra Turbo > V8
Floor mats for an FG XR50 ute, im assuming these are rare as hens teeth.
23-12-2023, 11:39 PM | #1754 | ||
24-12-2023, 08:36 AM | #1755 | |||
Barra Turbo > V8
Appreciate it
01-01-2024, 11:00 AM | #1756 | ||
Hi mate,
I'm after the external black XR door belt moulds, boot seal, the rear door seal mouldings and also the boot rubber mat to suit a 2015 FGX XR8 if possible please. |
01-01-2024, 02:13 PM | #1757 | |||
When you say belt moulds do you mean the moulds at the bottom of the windows? If so below are the prices: RHF: $65 LHF: $65 RHR: $85 LHR: $90 Boot Seal: $95 Ford never did a rubber boot mat, only the plastic feel type which is $160. I am not sure what you mean by rear door seal mouldings, if you mean the ones that run along the top of the arch of the rear doors then they are: You sitting down. RHR Door: $1100 LHR Door: $550 Add freight to the above.. GT |
01-01-2024, 02:24 PM | #1758 | |||
Hey mate, The part number for one of the rear door seals is bgf25504a1 if that helps, I'm after left and right sides. |
01-01-2024, 02:48 PM | #1759 | ||
01-01-2024, 03:38 PM | #1760 | ||
01-01-2024, 03:59 PM | #1761 | ||
01-01-2024, 04:00 PM | #1762 | ||
02-01-2024, 05:15 PM | #1763 | ||
Hey there,
Can you still alloy pedals to suit a manual? Its for a BA2 but they look the same all the way through to FGX? Plenty auto ones around but cant find anything for manual. Cheers, Phil |
02-01-2024, 09:38 PM | #1764 | |||
Not sure if the F series ones fit on a B series?? |
02-01-2024, 09:46 PM | #1765 | |||
They look much the same but I cant be 100% sure, I bought one for the brake a while back as thats all I could find, it was listed for ba-fg so assume they might be the same, worth a shot anyway. How much is the clutch pad if available? The acceprator is fine so all good there just brake and clutch pads have been work through on one side. Thanks for looking. |
02-01-2024, 09:59 PM | #1766 | |||
02-01-2024, 10:19 PM | #1767 | ||
03-01-2024, 03:03 PM | #1768 | ||
03-01-2024, 04:54 PM | #1769 | ||
You wouldn’t have any surplus stock of “December” would you? There’s a bunch of stuff I was hoping to get done by year’s end, and the only way I can make that happen is to find another month in 2023!
More seriously, appreciate the advice you’ve given here and the many times you’ve dropped off parts to me; hope the new year sees you happy and successful. |
03-01-2024, 11:02 PM | #1770 | |||
Glad to have helped in some capacity. Happy New Year to you and your. Thanks for the message. |
4 users like this post: |
