Stingray
Old 10-05-2023, 04:13 PM   #1411
GTLEGEND
Originally Posted by Citroënbender View Post
The arrow points to where a steel water transfer pipe sockets into a cast alloy housing which also supports the thermostat above.
(Picture from BBT Jap Parts of Lambton NSW, via Fleabay.)
Is the o-ring seal for that steel pipe, anything unusual like a square profile? I have a modest leak on the Territory’s one, and maybe also the white ute… If it’s a specific Ford part, are they still available? (I’m using 2:1 green coolant which has a knack of finding small leaks.)
Normal round profile O ring, not specific for Ford I guess, but you can still get new. $5.50 each..
Old 10-05-2023, 05:37 PM   #1412
XR Martin
XR Martin's Avatar
Ford one is green. Not sure if it's a different material than your average o-ring, but for the sake of $5 why would you bother trying something else.
If the original lasted 10 years that means you shouldn't have to worry about it for another 10.
2004 BA wagon RTV project.
Old 10-05-2023, 10:06 PM   #1413
au2000
AKA "the other bloke"
au2000's Avatar
Hi all.. just hunting a fg fpv lower grille surround? Hopefully someone can point me in the right direction. Thanks
Her's: 2000 AU II Fairmont Ghia 75th anniversary VCT meteorite & 2014 yaris - white
His Toy: 2012 fg II GT-E, emperor red
His: VS Ute 5 Litre 5 speed (povo pack)
His: 2012 FG II GS, Vanish
His: 2003 BA GT-P, Lightening Strike
Jnr: 2002 AU III Falcon XR6 ST, 5 speed Blueprint & 1978 XC Fairmont Neptune Blue
Previous:
1976 HX 50th Anniversary Kingswood
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
au2000 is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2023, 10:13 PM   #1414
GTLEGEND
Need to be more specific, there are 4 different lower grille surrounds on FPV specific front bars, one for GT/Pursuit, one for GTE/F6E, one for GTP/Super Pursuit or F6? Which one you chasing?
Old 11-05-2023, 04:50 AM   #1415
au2000
au2000's Avatar
Tbh im looking at either a GTE one or a GT one...
Previous:
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
Old 11-05-2023, 07:56 AM   #1416
GTLEGEND
GT one is obsolete which was a black finish, GTE is a chrome finish and can get, but they are (hope your sitting down) $1400. Just to confirm, we are talking about part 17D749A in pic below.
Old 11-05-2023, 09:58 AM   #1417
au2000
au2000's Avatar
i was thankfully.... but expected as much....
im assuming that part 17D749B relates to the F6 ? if so.. im assuming obsolete also?
But thanks for the confirmation GT Legend..
Previous:
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
Old 11-05-2023, 09:59 AM   #1418
au2000
au2000's Avatar
btw.. 8422 ? available for a GTE also?
Previous:
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
Old 11-05-2023, 04:36 PM   #1419
GTLEGEND
F6 was a Graphite Metallic colour, yes obsolete as well, but only recently.
Old 11-05-2023, 04:39 PM   #1420
GTLEGEND
8422 is the same for all, but obsolete as well.
Old 11-05-2023, 06:36 PM   #1421
Can you help this new member with his XC Distributor rotor search please https://fordforums.com.au/vbportal/f...php?t=11497931
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 12-05-2023, 06:03 PM   #1422
au2000
au2000's Avatar
Gt legend, 1 last question if I may, for 17D749A does that need another part to attach behind it ? If I read it right , that one is 2 parts, the frame and grille, but the top grille is 3 seperate parts?
Previous:
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
Old 12-05-2023, 06:14 PM   #1423
GTLEGEND
So the lower opening has a grille and moulding held in with screws.
The upper grill is the same, the third part you see 17C881 is an energy absorbing foam pad.
Does that answer your question?
Old 13-05-2023, 03:02 PM   #1424
au2000
au2000's Avatar
absolutley GT Legend.. just means it's 1 less thing ill be hunting for ! Can't thank you enough for your imput.
Previous:
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
Old 13-05-2023, 08:58 PM   #1425
bondy99
GT
I have a power steering rack on my AU2 6 cylinder that might replacement. Can any other model apart from AU2 fit or needs to be only AU2?
Thanks
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2023, 10:14 AM   #1426
GTLEGEND
Originally Posted by bondy99 View Post
GT
Thanks
There are 6 different racks in AU-AU2-AU3 Series, breakdown below:
6 Cyl: Forte, Futura, XR, S & Fairmont Sedans AU/AU2/AU3.
8 Cyl Forte, Futura, XR & Fairmont Sedans, Forte/Fairmont Wagon. AU/AU2/AU3.
6 Cyl Ghia AU AU2 AU3
8 Cyl Ghia Tickford Fairlane & T Series AU AU2 AU3
6 Cyl Fairlane/LTD AU AU2 AU3
8 cyl Fairlane/LTD AU AU2 AU3
So based on this, unless yours is a Ghia or Fairlane/LTD, you would need to find one out of any AU/AU2/AU3 that us a Forte/Futura/XR/S or Fairmont.
Old 14-05-2023, 11:38 AM   #1427
78xcgxl
78xcgxl's Avatar
Hi GT, I am wanting to do the FGX black headliner conversion to my FG Mk2 XR6T ute. Just wondering on the availability of parts, part numbers and prices when you have a chance. Thank you
78xcgxl is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2023, 11:56 AM   #1428
GTLEGEND
Hey mate,
Here is a list of all the parts required and their part numbers. Most are no longer available. I will need to go through and update whats still available and their pricing, but most are long gone now as another member not long finished doing the same thing and is still missing items. I think easiest option would be to find a wrecked FGX and get all the trims from it.
RH A Pillar trim: AR2ZF03512CBSH
LH A Pillar trim: AR2ZF03513CBSH
RH B Pillar trim: 8R2ZF24396ACSH
LH B Pillar trim: 8R2ZF24397ACSH
B Pillar Screw Cap: 8R2ZF24452BBSH (you need 2).
B Pillar Seat Belt Bolt Cover: 8R2ZF610C29AASH (you need 2).
RH C Pillar Trim: AR2ZF31002ACSH
LH C Pillar Trim: AR2ZF31003ACSH
RH Sunvisor: 8R2ZF04100ABSH
LH Sunvisor: 8R2ZF0410ABSH
Sunvisor Retaining Clips: 8R2ZF041K16AASH (you need 2).
Roof Lamp Bezel: 8R2Z13K767CASH
Rear Side Lamp Bezel: WR2Z13A701AFSH
Rear Roof Lining Clips: W713485SSSH (you need 2)
RH Grab Handle: 8R2ZF31406ABSH
LH Grab Handle: 8R2ZF31406BBSH (you need 2).
Old 14-05-2023, 06:12 PM   #1429
GXA
Hi GT,
Have a 2008 FG GT-E.
Looking for wiper arm caps, and also the y piece for the washers that clips into the passenger side firewall. It has an internal non-return valve.
Thanks
Our FORD Stable
2008 FG GT-E - Lightning Strike
2015 SZII Territory TS - Winter White
2007 BFII Falcon ES - Ego
GXA is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2023, 09:17 PM   #1430
GTLEGEND
Originally Posted by GXA View Post
Hi GT,
Thanks
Wiper arm caps, part number BGF04178A, obsolete and non around unless someone has in their private stash. 2nd hand may be your only option at the moment.
Washer Y piece is actually part of the LH wiper cowl panel and you have to buy that to get the Y piece. $85 plus postage.
Old 14-05-2023, 10:09 PM   #1431
GXA
Thanks for the prompt reply.
Our FORD Stable
Old 15-05-2023, 02:32 PM   #1432
Vicusj
Thanks
If this might help out anyone, I had issues with my Territory's non-return valve perhaps 10 years ago and fitted an ~$3 aquarium air pump non-return valve as a "temporary" solution. It is still working perfectly to the day (unless I have now jinxed it!)
'19 Wildtrak PX3 3.2 6spd, White
'09 SY1 Terri TS AWD - still going strong, now wifey's
Vicusj is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2023, 06:05 PM   #1433
78xcgxl
78xcgxl's Avatar
Hey mate,
Cheers mate, I figured most would be obsolete my now. Being a Ute, I need a few less parts. I see you can still get sunvisors online at Bayford, hence i had a little bit of hope. Clips wise I'm not too fused, I'd just paint the cream ones. I agree with finding a wreck but there were not many FGX XR UTEs made in the first place and people want more $$$ than new parts. If I could the get info on the smaller list below when you have a chance. It would be much appreciated and i will reassess my options. Thank You
- Both A Pillars ( G6ET fabric ones or just standard XR)
- Ute B Pillar trims and screw caps
- Ute Small interior light bezel ( nea rear window)
- Ute Seat belt screw caps
- Ute headliner
- Standard Map lights between sunvisors ( i highly doubt a sunglasses holder one is still available)
- 1x LH grab handle.
Old 15-05-2023, 06:52 PM   #1434
GTLEGEND
- Both A Pillars ( G6ET fabric ones or just standard XR) RH Cloth Trim $140 or Moulded Plastic style $40. LH Cloth Trim $120. LH Moulded one is obsolete NLA.
- Ute B Pillar trims and screw caps (Guessing upper) RH $60 LH Obsolete Screw caps also obsolete.
- Ute Small interior light bezel ( nea rear window) $15
- Ute Seat belt screw caps $5
- Ute headliner Obsolete
- Standard Map lights between sunvisors ( i highly doubt a sunglasses holder one is still available) Std $200 Sunglass Holder Obsolete
- 1x LH grab handle obsolete.
Hope that helps.
Old 16-05-2023, 08:19 AM   #1435
mchaggis
mchaggis's Avatar
Hi GTLegend, I'm after the three FPV badges for a B series Tornado Ute. Specifically the tailgate FPV badge (Not the F6 Tornado badge), and the two FPV badges that sit in the left and right skirts in the recessed area near the front wheels. They are a two piece badge, one part is the FPV logo, the other is the text FPV.
Cheers.
The Current Fleet:
2018 Kia Sportage GTLine
2014 FG-X G6E T
2012 FG-II GTP #288
2002 AU-III XR8
(1977 TE Cortina, 2001 AUII XR6, 2004 BAI XR8 Ute, 2005 BAII Typhoon, 2008 FG F6, 2015 FG-X XR6 Ute, 2006 SY Territory Turbo Ghia...it just used too much fuel)
mchaggis is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2023, 04:41 PM   #1436
GTLEGEND
Cheers.
Hi mate,
Tailgate and side FPV Badges in this case are all the same. Part number BAT16237A, obsolete but there is one on eBay.
https://www.ebay.com.au/itm/25576862...Bk9SR66irbSEYg
Cheers,
GT
Old 18-05-2023, 09:19 PM   #1437
portokatsiki
Hey legend
2007 territory turbo oxygen sensor price please if still available. Does it have 2 sensors like the v8s or 1?
Thanks
portokatsiki is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2023, 09:37 PM   #1438
GTLEGEND
Originally Posted by portokatsiki View Post
Hey legend
Thanks
Hi mate,
2007 TT has only 1 O2 Hego Sensor. $270 plus postage if required.
GT
Old 19-05-2023, 04:17 PM   #1439
au2000
au2000's Avatar
sorry GT Ledgend.. last one .. i promise ! 8169 to suit a GTE?
Previous:
2014 FGX G6E Turbo
1980 XD Falcon GL
2003 BA Falcon XR6
1991 EB Falcon S
1989 EA Fairmont
1982 XE Fairmont
1968 XT Falcon
Old 19-05-2023, 04:51 PM   #1440
GTLEGEND
No drama keep them coming. So GTE will have a Bright Chrome Finish, still available at $250 plus postage if required.
