Old 12-07-2021, 10:05 PM   #1
leesa
Default Re: Need a new modem/router
Originally Posted by car10002 View Post
Also if at cabins and you want to have a 4g modem and also a wifi reciever to use at places that have wifi and be able to create your own can you use a hub and connect the 4g modem and cpe ethernet that’s used to pick up parks wifi when there’s wifi and plug either into wan port or both if hub is used
In other words do you use wan port or any lan port in a wifi router when using as a access point
Almost anything is an option if you get the right gear and configure it properly, but most residential-grade equipment isn't particularly verbose when it comes to configuration options.
What is it that you're actually wanting? The option of using both 4G and wifi when it's available? wifi preferrably but auto-fallback to 4g when it's not?
As a side note I don't think you'll even find a hub on any store's shelf anymore, it's all just switches now.
