05-02-2021, 09:40 PM | #1 | ||
Hi everyone,
I'm not sure if this thread is in the right section & if not by all means move it. I have a lawn mower that decided it didn't want to play anymore and just stopped suddenly & wouldn't start again. After going through the normal procedure of process & elimination to no avail I did what I should have done initially, a compression test, as I didn't feel that it was a fuel or electrical issue as it was just too sudden a stop. The result was zero compression. So after removing the cylinder head I found what I suspected that the intake valve seat had dislodged. Given that I've been & spoken to a number of mower repair places I'm starting to feel I'm missing something here as I couldn't get a definitive solution to stop this happening again. So I Googled it only to find that the popular solution was to use a broad point punch and not aggressively just carefully punch small indentations in the block around the perimeter of the valve seat about 5mm from the edge. When the motor/block heats up & being alloy it expands these indentations causing extra retaining pressure around the valve seat limiting the likely hood of it popping out again. That's the theory anyway. So what happens when the block is cold what's to stop it from popping out?? Furthermore I just don't like the idea of punching indentations in the block. Does anyone know of a better alternative or solution? Sorry about the long thread. Cheers Grahame. Last edited by BlueEA; 05-02-2021 at 09:44 PM. Reason: Correction |
05-02-2021, 10:35 PM | #2 | |||
I'm probably not the best person to reply to your Question, though.. As far as I'm concerned Anything Briggs & ****ten is just throwaway Rubbish..!!! SORRY.. |
05-02-2021, 10:57 PM | #3 | ||
Like this; https://www.youtube.com/watch?v=6JL2tyNqBJ4 ? And yes it's also what the Briggs and Stratton Factory Workshop manuals says to do.
regards Blue Last edited by aussiblue; 05-02-2021 at 11:02 PM. |
05-02-2021, 11:14 PM | #4 | ||
I'll let you in on a trade secret, I also encountered the problem of no compression on my mower.
This is how I fixed valve seat issues on my Briggs & Stratton lawn mower. 1) Throw out old lawn mower 2) Buy $179 lawn mower on special at Aldi |
4 users like this post: |
05-02-2021, 11:31 PM | #5 | ||
Here's a copy of the page from the Briggs and Stratton Factory Workshop Manual. And if think that is crude, they also use a special knurling tool to knurl a pattern on worn cylinder walls to reduce their internal diameter. You need a different mind set when dealing with these cheap motors compared to car engines etc, They always were cheap and relatively disposable even made in the USA now being made in China they are even cheaper and more disposable. So yes usually it's cheaper and more sensible to buy a new mower than buy any parts costing more than a few dollars. But I know where you are coming from and I have to admit I keep repairing old mowers that I never use just for the fun of it. I use a Ryobi rechargeable one these days; lighter and much quieter and more reliable. In fact it's so light and easy to use the missus does the mowing for me now.
regards Blue Last edited by aussiblue; 05-02-2021 at 11:42 PM. |
05-02-2021, 11:38 PM | #6 | |||
And its amazing what info aussiblue has. |
5 users like this post: |
05-02-2021, 11:45 PM | #7 | |||
In theory it should have instant torque but I see they use 2x 18V lithium ion batteries that a drill uses and I'm very suspicious on how effective that would be as it's not much juice at the end of the day. |
05-02-2021, 11:51 PM | #8 | |||
1. Doing a quick prowl of the few bookshop in Perth most lunchtimes looking for bargains for the 50 years odd before I retired. 2. Being brought up in relative poverty on a dairy farm in a very isolated part of W.A. (Northcliffe) where if anything broke down it was fix it yourself or go without. 3. No TV in Northcliffe at the time either so reading and collecting books was ingrained. 3. Perhaps/maybe I am a bit of a hoarder too. Well My missus thinks so but I am not convinced.
regards Blue |
14 users like this post: |
05-02-2021, 11:57 PM | #9 | |||
My son has this two battery Ozito https://www.bunnings.com.au/ozito-px...r-kit_p0244221 ; it's heavier than the Ryobi and awkward to change the cutting height.
regards Blue Last edited by aussiblue; 06-02-2021 at 12:12 AM. |
06-02-2021, 12:50 PM | #10 | |||
Former BTIKD
57v. 5ah battery which lasts for about 40mins, 30 min recharge time. The downside is the kit (Mower/battery/charger) costs about twice the price of a petrol mower.
06-02-2021, 01:40 PM | #11 | ||
my opinion ~ i wish two of my neighbours had them when they decide to mow at 7am on the weekend . its always a joy to know that they are up
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
6 users like this post: |
06-02-2021, 01:47 PM | #12 | ||
06-02-2021, 01:53 PM | #13 | ||
08-02-2021, 08:09 PM | #14 | ||
Blue EA
Ive got an Ed Yes try that as they say , should work and cool it maybe in dry ice ,before assembly and also heat the ally part , this will really help it lock in A simple valve regrind in ,,,,,,,,and hone the cylinder,,,,,, with cross hatching,,,,,,, with some emery paper , by hand , and hard scrub with detergent , and your ultrasonic cleaner is probably not big enough to put the inserted valve seat and cylinder in , so a hard scrub with detergent A really good project
Fords are cool |
