Old 12-09-2012, 09:19 PM   #1
xtraktor
fte or fpv, mmmm....
Default AU weak air con fan
Hi Guys,
Just want to check if it is me going crazy spending too much time in the AU, or is the heater/dash fan becoming weaker with age?
I used to be able to hear it on speed '2' but now I struggle to hear even speed '3' and have to have it on '4' to get any decent air flow.
Is this a known issue? how can I fix it?
xtraktor is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2012, 01:55 PM   #2
mik
mik's Avatar
Default Re: AU weak air con fan
mine works fine all four speeds, i`m thinking i would check the fan speed resistor and the fan speed switch.
Old 14-09-2012, 10:02 PM   #3
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Originally Posted by xtraktor
Hi Guys,
Is the fan still working on the lower speeds?
If yes, it is likely that the Evaporator is becoming clogged, with dust, hair and *****.
Not an easy repair.
Got the same issue btw!
MNM96 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2012, 10:10 PM   #4
xtraktor
Yes the fan still works on 1 and 2 but you can barely feel it. I will check the cabin filter but I don't hold much hope, my car is spotless inside so why would it be clogged?
Old 21-12-2012, 12:58 AM   #5
joblue
I am pulling out the dash of an AU11 tomorrow for the same problem I;ll try to let you know how it goes
:togo: joblue
Mine FG XR8 Ute (Luxury Pack Manual)
Hers FG GT 315
Spare XC GXL 351, 5 speed T5, twin gas research matching numbers ( Luv The old Girl)
Buy Australian
joblue is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2012, 07:41 AM   #6
MNM96
MNM96's Avatar
I pulled the dash from mine and was none the wiser. Need to attack it from the underbonnet side I believe.
Old 21-12-2012, 05:28 PM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
There's no cabin filter in AU's
The blower unit is visible when you take the glovebox out, however it is a dash-out job to replace it. This was rectified with the BA's and onwards.
AU falcon fan performance is unbelievably dismal at the best of times. It's sad when mid size jap econoboxes 10 years older than it have massively superior fan performance
Old 05-12-2020, 12:07 PM   #8
afg
Leaking vac or vac tank switch failure vac operates aircon doors doors closed no air
afg is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2020, 08:00 PM   #9
George V
Welcome to Australian Ford Forums AFG.
Almost eight years since last post on this topic.
Anyway, I still got an Au and still got similar fan issue.
Perhaps, I will check vacuum switch one day.
Kind regards,
George V
George V is offline   Reply With Quote Multi-Quote with this Post
