Old 06-01-2020, 09:47 PM   #1
Default Engineering Nomenclature Question
Correctly, what is this “pin” called (in English)?
I’m stumped, most of the “knurled pins” per Google Images either have a splined butt or diamond knurling. Dowel pins appear to be smooth.
Old 06-01-2020, 10:12 PM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default Re: Engineering Nomenclature Question
You have also stumped the 'reverse google image' search function.
First result with the original picture says you have plywood.
Second search I zoomed right into just the metal bit.
Apparently google tells me the thing in the picture is called a... 'Parallel'...
Good luck CB - looks like something out of an IKEA kit.
___________________________
Old 06-01-2020, 10:13 PM   #3
Yellow_Festiva
Where to next??
Actually - could it simply be a wooden dowel painted silver??
Old 06-01-2020, 10:20 PM   #4
They’re the tapered end, parallel splined pins driven into a BA-BF steering column to secure the ignition switch. Small, plated steel items. I’m sure they wouldn’t be a proprietary FoMoCo part.
Just looking for a few spares to satisfy my urge to tinker.
Old 06-01-2020, 11:09 PM   #5
[Straight] Knurled dowel pins. See https://www.machinedesign.com/fasten...retaining-pins and https://www.efc-intl.com/products/sp...h-centered.htm
Old 06-01-2020, 11:25 PM   #6
Spirol will have them https://www.spirol.com/mkt/rs1.php?search=5 and this company sell Spirol stuff in Oz https://www.minibearings.com.au/
Old 07-01-2020, 12:11 AM   #7
Note also that it is often better to swap from straight knurled to spiral/helical knurled and visa versa so they grip better if the hole they are going to be inserted into is the old one and unchanged.
Old 07-01-2020, 03:13 AM   #8
Proton energy pill.
I've known them as knock pins or anti-vibration pins, designed to not come out once installed.Similar to a roll pin/split pin.
