#241 | ||
ARE THERE ANY DIFFERENCE IN SWAY BAR DIAMETER FROM FORTE TO XR SERIES ON AU S/3's
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
#242 | ||
BSR
Part number for chrome ring that sits under manual gear knob on t series?
FPV GT 725 with a few options including the stars........ |
#243 | ||||
You can't stop the signal
#244 | ||
Since buying my AU XR6 I have managed to fix quite a few things myself and therefore saved a few dollars. The info on the forum is great. So far I have fixed
Power window button Spanner symbol on dash Brake pads Door handle Just need some tyres and I'll be on the road. Thanks to all the posters!! |
#245 | ||
Hi Russ,
I've tried the parts list, was wondering if it includes tail lights? |
#246 | ||
Search for them under LAMP ASSY
Cheers Russ
#247 | ||
yeah it isn't on there, it only has lights for AU2 and 3, i'm after AU1. its a long rectangle. don't know if that helps at all?
#248 | ||
They are in there - there is no difference in tail lamp assemblies across all of AU -
Normal tail lamps - ER 13404 A LAMP ASSY - REAR, RH, 4 DR SED, FORTE/FUTURA/"S"/XR ER 13404 B LAMP ASSY - REAR, RH, 4 DR SED, FORTE/FUTURA/"S"/XR ER 13405 A LAMP ASSY - REAR, LH, 4 DR SED, FORTE/FUTURA/"S"/XR ER 13405 B LAMP ASSY - REAR, LH, 4 DR SED, FORTE/FUTURA/"S"/XR Rear Spoiler Stop Lamp AU1 ER 13A582 A LAMP ASSY - REAR, INCLUDES LAMP HARDWARE, FOR SPOILER, CENTRE, 4 DR SED, FORTE/FUTURA/"S"/XR AU2 AU2 13A582 A LAMP ASSY - REAR, INCL. HARDWARE, CENTRE, 4 DR SED High Mount Stop Lamp ER 13A613 A LAMP REAR HI MOUNT, 4 DR SED, (-) XR LTD TAIL LAMPS LR 13404 A LAMP ASSY - REAR, RH, LTD LR 13405 A LAMP ASSY - REAR, LH, LTD FAIRLANE TAIL LAMPS NR 13404 A LAMP ASSY - REAR, RH, FAIRLANE NR 13405 A LAMP ASSY - REAR, LH, FAIRLANE Cheers Russ
#249 | ||
tried to find an AU (DU) LTD grille in the database but couldn't find it can you help?
[SIGPIC][/SIGPIC]
Everyone starts off with a bag full of luck and an empty bag of experience. The trick is to fill the experience bag before the luck bag is empty. "It is better to remain silent and be thought a fool than to speak out and remove all doubt." Start a new career as a bus driver Rides: FG2 XR6 stock at this stage but a very nice ride xc 4 DOOR X CHASER 5.8 UNDER RESTO Last edited by FGII-XR6; 23-02-2011 at 07:52 PM. |
#250 | ||
As far as I know they are obsolete but the part number would be DU 8200 A or similar.
Cheers Russ
#251 | ||
thank for that
[SIGPIC][/SIGPIC]
#252 | ||
Guy's,
Are the Silver trim that fits in the rebate of the front bars of the XR's still available. Regards |
#253 | ||
Are the repro AU1 bonnets (as in, those which fit an XR) all rubbish, or are there any worth looking at?
Don't fancy my chances of finding a clean Liquid Silver bonnet any time soon. Rust has destroyed the other one from the inside out, front lip and 3" back. |
