Old 12-03-2017, 07:34 PM   #361
Default Re: What made you feel good today?
On Friday. I got a call from a building manager to go sort out the contractor one of his tenant's use who had been trying to get to the bottom of a problem for a couple of hours. Turns out it was one of the tafe teachers I had in 2007. A top bloke and after I sorted his problem in 20 or so minutes we caught up for a bit then went on about our business. It feels good being the (ex) student who just schooled the teacher.
Old 12-03-2017, 08:46 PM   #362
Beastie
The Terrain Tamer
Beastie's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Catering services for a bunch of layabouts and for being an all-round good guy whose sense of community goes above and beyond.
My wifey's Apple Strudel that she made for dessert tonight...
Current Ride : A Ford owned D3...
Beastie is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2017, 08:49 PM   #363
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
doesn't take much to make you happy..... does it?
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2017, 08:58 PM   #364
uniacidz
uniacidz's Avatar
Did a wheel alignment on the car myself today as couple months back changed the tie rod ends but finally fine tuned it today.
3 test runs after adjustments then finally spot on
Sent from ASUS ZE551ML ^_^
Before -
ED Falcon Futura (sold)
EL XR6 (R.I.P.)
VX SS (R.I.P)
VE Berlina
uniacidz is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2017, 10:36 PM   #365
ebxr8240
Performance moderator
ebxr8240's Avatar
I made up a bee's wax solution.. Then got up on roof of motorhome over 2.6m high.. then applied the wax over roof to assist big time in water repellent.. Its a rubber over ply.. Fitting between vents, sat TV dish,TV arial , solar panels, CB etc.. The wax made roof VERY slippery .. Lucky my occupation was line worker. Where heights is not an issue.. 63 year old.. Have to keep preventative maintenance up on these expensive things..
Daily driver GTE FG..
Old 12-03-2017, 11:06 PM   #366
XB GS 351 Coupe
Finally had a day off today after doing 78 hrs since Tuesday this week....next feel good moment will be when my next pay comes in
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2017, 11:08 PM   #367
BPXR6T
Turning the key in my 64 year old never rebuilt tractor and it firing right up after six months idle. Then it goes on to put in a full days work without missing a beat. Got to love british engineering.
BPXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2017, 11:20 PM   #368
CoupeKing
Yesterday discovered a small shopping complex (old school) near me that has a pizza, fish n Chip and chicken/chips shop next to each other. Gonna give my arteries a real good work-out over the next few weeks.
CoupeKing is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2018, 10:18 PM   #369
The "Why is it...." gripe thread has had a bit of a run lately. Well for a little balance I thought it wouldn't hurt to revive some feel good.
After a week of working outside in 40+ heat and no sleep last night, two latte's, a drive in the Mustang and pumping some new music made me feel good this morning. Its the little things..............
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
Old 27-01-2018, 10:58 PM   #370
Can I do yesterday??
After about 18 months of not being overly happy with where the Pedders Sports Ryders had my ute sitting, I finally got around to taking a further 25mm out of the rear, while at Total Tools picking up a steel cut off wheel for my grinder to remover the excess off the new u-bolts for the blocks
•I caught a glimpse of it in the mirrored front windows of the shop
• the rubber clears the guards by about 7mm so I don’t need to roll them
Old 28-01-2018, 12:11 AM   #371
d@rk51d3
Been waiting for a replacement condenser fan for the AC at home.....
Decided to open up the old one, and lube up the bearings, and press it back together. Working like a champ. Then it hit the mid 40's and she went into high temp limp mode.
Pulled the dash out of the F250 (wasted a heap of time figuring out the speedo cable removal), and removed the headlight switch (installed upside down - button on the bottom) as I wasn't getting any dash lights.
Cleaned out a heap of crud, dressed the contacts. Light spray with inox, then a blow with compressed air. Chucked it all back together....... good as new.
d@rk51d3 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2018, 12:18 AM   #372
Trump
bitch lasagne
Trump's Avatar
KFC chips.
Scaled Business Solutions
For Your Small Business IT Needs
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2018, 12:20 AM   #373
d@rk51d3
Originally Posted by Trump View Post
KFC chips.
That'll work.
Old 28-01-2018, 12:22 AM   #374
Mechan1k
Mechan1k's Avatar
KFC chips.
With potato and gravy
Old 28-01-2018, 12:51 AM   #375
Just got home from a quick cruise to Kalorama and back
( Hungry Jacks chips are better )
Old 28-01-2018, 12:58 AM   #376
TICKFORD220
2009 Fg xr6 turbo
Feeling like im finally getting somewhere with this bf,had it for a month and finally went for a decent drive today and gave it a good touch up.Had to reset the ecu after fitting a few new parts,cai,exhaust,02 sensors etc and the old girl is going a lot better,looks to be getting almost 600 km mostly city miles out of the first tank,pretty stoked,made me feel good today
Hungry jacks chips are better than kfc by a long way and red rooter chips blow them all out of the water!
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2018, 01:01 AM   #377
Ford screwed the Falcon
I got a hint earlier today that a lady may be interested in me. We have an opportunity to meet this upcoming Friday as part of a larger group so there won't be the usual pressure of the 1 on 1 date.
6 users like this post:
Old 28-01-2018, 01:34 AM   #378
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
This was fun.
I doubt my parents will be happy when they get home and see what I did to the driveway though.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2018, 01:39 AM   #379
Mechan1k
Mechan1k's Avatar
At least you lined it up perfectly in the middle ... adds more detail to the concrete.
Petrol will clean it up though.
Old 28-01-2018, 01:51 AM   #380
commodorenutt
commodorenutt's Avatar
A+ for consistency.
Don't know that I'd want to be in your shoes tomorrow though....
commodorenutt is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2018, 01:55 AM   #381
Junkyard-Dog
*barks incessantly
I had to do better than the poxy ones dad did with his ute to the right hand side of the drive-way sometime last year... he got a blasting from the old bird and as you can see, he barely even left a mark
Old 28-01-2018, 02:09 AM   #382
commodorenutt
Mum, you should have seen it, a DeLorean screamed up the driveway at 88mph and vanished, leaving those 2 tracks......
Old 28-01-2018, 02:30 AM   #383
Junkyard-Dog
*barks incessantly
I'd like to see them prove that it didn't.
Old 28-01-2018, 02:43 AM   #384
PG2
#neuteredlyfe
PG2's Avatar
Any chance you could video your parents reaction when they arrive home tomorrow and post it up on youtube?
Old 28-01-2018, 02:54 AM   #385
Junkyard-Dog
*barks incessantly
I'll see what I can do.
Old 28-01-2018, 02:56 AM   #386
Sar4890
Sar4890's Avatar
Taking my coupe out for a run along the coast.
Sar4890 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2018, 01:43 PM   #387
danzvtil
danzvtil's Avatar
Been sleeping in my lounge under my new dirty great big split system ac, 2 days of 42 deg, it cools like nothing else when my Evap would struggle....
____________________
2019 LDV G10
2009 Mitsubishi Express-GONE
2011 Honda Jazz
danzvtil is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2018, 03:05 PM   #388
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Nice one
Much the same here, just did 31 hours over two days on the perth skyshow set up and pack down. Slipped into the Cortina this morn and listened to the golden oldies station on the crackly am radio as I drove up the coast.
Lots of cars out, everyone waving at each other. Good vibes all round.
I might even go back out this arvy in the Escort...
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 28-01-2018, 03:44 PM   #389
commodorenutt
Finally cured the overheating issue in my VL Brock. Took it on a stop-start drive for over an hour, with the A/C on, and the hottest it got to was the 2nd bar from stone cold. Didn't want to stop driving it!
Old 28-01-2018, 07:43 PM   #390
Reading that post
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
