07-05-2016, 09:43 PM | #1 | ||
Hi!
So quick summary. I went to work in the AU a few months ago. No bingo. It turned out to be the fuel pump. I tried replacing with a walbro in tank and it was super rich. I found a full pump and replacement cradle on ebay to see if that at least got it going. It got worse.. it barely idles in gear (brake and throttle required), quick rev results in a huge black spot on the ground and huge cloud of smog. So far I have put new fuel and some injector cleaner in, wiped retuned, tried to reset idle.. My thoughts are potentially fuel filter? O2 sensor? Has anyone had this issue or does anyone have ideas? Cheers in advance!
Daily: AU Forte Wagon Project: AU Fairmont - Wants to be turbo The Family Car: 2009 G6E Turbo Future fun: 1968 Ford Galaxie 500 |
08-05-2016, 07:54 AM | #2 | ||
Spanner Thrower
Sounds to me if you need brake and throttle it's a bit more then a fuel issue, that part sounds more like a vacuum leak to me.
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
08-05-2016, 11:34 AM | #3 | ||
Pretty common for fuel reg to block up and not let excess fuel back to tank. Also have seen return line rust up causing same issue. A fuel pressure test will confirm
08-05-2016, 11:53 AM | #4 | ||
09-05-2016, 02:48 PM | #5 | ||
That makes perfect sense (block return line). The way it acts sounds plausible.
I will see if there are any obvious blocks, leaks etc and get back to you. Thanks guys.
19-05-2016, 10:57 PM | #6 | ||
Success. Issue was the regulator.
Thanks all for the advice!
