Hi guys, just looking for some advice.
I'd like to get an exhaust system done up that allows me to change from "moderate" to "loud", and vice versa, without going back to the exhaust shop each time. I know there is the VAREX type system but I'm not really interested in that as I don't want to "block" the pipes. I just want to be able to swap out mufflers / straight pipes to get different sounds. Has anyone had an exhaust shop done up a system that allows easy swapping in and out of certain sections? Is it easier to go with a system that allows swapping out the tail or mid section? Any drawbacks e.g. will I get exhaust leak at the flange if I'm constantly unbolting and bolting? Would be keen to hear how others have done it. |
Hi. No reason at all that an exhaust place cant make a system with different mufflers that fit in the same place other than you will need to buy 2 or 3 cat back systems in one hit. Other problems may be getting a muffler that sounds good in one system to sound good with another resonator or straight pipe or larger or smaller pipe. All of a sudden the Varex muffler might be the cheaper option, plus no lying on your back in the cold changing a muffler to get a RWC when you can turn it down before you attract attention. Cheers MD
Bolt Nerd
![]() Join Date: Jan 2005
Solenoid operated dump pipes..
http://www.ratsport.com/Mobile/MBSCP...?pdtid=9611815
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner ![]() |
3 users like this post: |
Buy a choke pull exhaust Y junction and run two exhausts, a cheap version of the varex.
Or one of the site sponsors, Venom exhaust makes a few different middle BA-BF sections that fit xforce systems etc, http://www.fordforums.com.au/forumdisplay.php?f=344 they sell straight pipes middle section, you can get full muffler middle section and hot dog middle section, that's 3 choices in the middle pipe section. |
Hot Rodders have been doing versions of this for years, as above either put caps on your full flow system or run a cable To to a junction valve
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
#7 | ||||
![]() Not sure on the design though. With the valve positioning, gas would still flow through both pipes. And with valve closed, I can see it creating a tonne of turbulence which is no good. Quote:
This is the one I'm looking at. When the valve is closed, I can see exhaust flowing through the secondary pipe and bouncing off the closed valve and reversing until it hits the next pulse. Would this not cause performance issues?
Also, if the valve is fully opened, I can imagine some air still going through the primary pipe? Wouldn't it sound odd? http://www.ebay.com.au/itm/2-5-Dual-...8AAOSwJMhXEKib |
Miami Pilot
I got a local bloke to make up 2 x flanged rear sections for my x-force system. 2 bolts each side, and 3 hangers in total and the rear mufflers are off and replaced with straight through 3" pipe. It is loud, and terrible when cold, but good when warm, expect at 1250 to 1750 rpm, but I just avoid that range. Cost me $300 all up (and it's full stainless). To keep gaskets sealing properly, the dude told me to use silicon with the gasket when I change rear sections.
My brother does his own systems out stainless, you can buy some very nice stainless fittings that allow you to remove bits /swap bits very quickly, I'll see if i can get the name of the company he buys his bits of, they may have a catalogue.
Think I may have found the solution. One of these right between the mid and rear muffler. Not sure if the BA falcon has enough room underneath to do it though...will look into it...
https://www.youtube.com/watch?v=CT8x9mMq3oU Last edited by T3rminator; 01-05-2016 at 09:01 PM. |
#12 | ||
This guy has the right idea....
http://cuthroatflow.com His design will remediate the tubulance issue! |
#13 | ||
i was going to buy a venom muffler delete mid pipe for the GT, it bolts in place of the factory or (xforce) system that i have. I haven't bought it yet as i never use the car but i entered it in summernats so if it gets approved i'll do it, just 4 bolts and i can swap it over
currently its loud for a road car but it would sound like a camry if i took it to summernats
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
#14 | ||
Have had it on a few cars I've had, just have flanges each side of the muffler so you can unbolt it and bolt in straight pipe/loud muffler etc
#15 | |||
Sent from my SM-N9005
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#16 | ||
Nah never, just had gaskets between the flanges,
#17 | |||
#18 | ||
Varex don't sound all that great..
Look up electric exhaust cutouts. You can get them for $232ea from VPW in any size. Up to you how loud you want it. Can place it after your headers, after your first muffler or after the diff but before the last muffler. Works like a charm and is good for drag racing, https://www.youtube.com/watch?v=2TrycvqeEmY |
#19 | ||
Spoke to my brother about where he sourced his stainless bits http://www.geordi.com.au/ , he reckons he used geordie stainless for some of his exhaust bits and they where very good , but some of it was a tad on the heavy duty side for car applications he reckons , now he gets a lot of his joiners and bits and pieces of ebay .
