does any one have a pic/drawing of where all the vacume lines go on a series 3 xr8?
cheers |
Which vacuum lines? The HVAC ones, underbonnet ones?
Cheers Russ
yeah all the small ones that come from intake and also the stuff for the charcoal cannister.
cheers |
Try this ....
cheers its more the engine side i need as i brought a xls ute rolling shell and put a 220kw v8 in it just trying to get it all plumbed in.
cheers |
You asked for the carbon canister which is why I used that one - can you try to be specific as we can't read minds. Not a lot of diagrams but here are a couple are a couple I found.
Russ
Next upgraded Mk1 Leopard
I knew you would say that
![]() UK
sorry where does the vac line go that come from the fire wall? and what connects to the 2 outlets at the front and rear of the upper intake?
cheers |
