Old 09-06-2015, 08:15 PM   #1
dom_105
Default Re-registering a previously written off car - VIC
Ok, story time.
A few years back I purchased a BA XR8 from a guy in Victoria who brought it down from NSW, where it had been written off as a repairable write-off. Prior to his ownership it was repaired poorly in NSW, and after it made the trip south it failed the VIV inspection in Victoria. I subsequently bought the vehicle and after a lot of stuffing around it passed the inspection, roadworthy and I subsequently got it on the road.
Fast forward to now and after years of the daily grind it's looking sad and sorry for itself. Over time it's revealed a few nasty surprises as well, so I'm starting to think about taking it off the road for a period of time and turning it back into something special.
Obviously it will always be a written off vehicle, it will always be on the register which is fair enough.
I suppose my question is this. I have always been under the impression that like a RWC, your VIV certificate was valid for x number of days. If I were to ever let the registration lapse, I would need to get a new RWC to get it registered (like any other car) and I would need to get a new VIV certificate and go through the whole inspection process again. Is this correct?
Or once it has passed a VIV inspection, though it will always be on the register, it will be treated like any other car?
dom_105 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2015, 08:20 PM   #2
dead_man00124
Default Re: Re-registering a previously written off car - VIC
my understanding is once it Passes the VIV thats for life, should update when doing a PPSR check saying previous write off(repaired)
dead_man00124 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2015, 06:53 AM   #3
LTDHO
The one and only
LTDHO's Avatar
AFAIK once it has passed a VIV it is taking of WOVR.
Personally, I'd call VicRoads and ask. Perhaps all cars must have to keep a history and once a Write off, always a write off.
Let us know how you go with Vic Roads.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2015, 07:22 AM   #4
xisled
It will always be a written off car, but instead of it showing up as written off it will show up as an inspected written off from memory or something similar.
You only need to get a RWC to get it back on the road. VIV only needs to be carried out once and if passed you will not have to get another VIV.
But IMO I would seriously considering taking it off the road and not putting it back on the road due to the nasty surprises you have found. The car could be a death trap.
You can pick up a BA XR8 these days for under 10 grand.
http://www.carsales.com.au/private/d...2596315/?Cr=15
xisled is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2015, 08:41 AM   #5
Trump
bitch lasagne
Trump's Avatar
How nasty are the surprises?
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2015, 09:28 AM   #6
zilo
BANNED
zilo's Avatar
I have put half a dozen back on the road.
The VIV is only done once...BUT...at times they forget to update the WOVR register and delays ensue getting it sorted out.
A written off vehicle is often just too expensive to repair, not necessarily a death trap.
hail damaged cars are a classic example of that.
and...the VIV is a rort, 500 bucks for nothing.
an absolute joke....
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2015, 11:35 AM   #7
dom_105
I actually did a PPSR check for ***** and giggles. The car is listed as being written off but the subsequent repair is not noted. There's a category on the WOVR in Victoria called "Inspected repairable write-off" so I guess that's where it is.
https://www.vicroads.vic.gov.au/regi...rite-off-types
So called VicRoads this morning, I was told that once it's passed a VIV Inspection, it won't need another VIV certificate unless the car is written off again. So that's good news, and different to what I thought, because that's a process you only want to do once in your life.
If I knew the hoops I would need to jump through to get it on the road, I wouldn't have touched it. But now the work is done and the front is nice and straight underneath. The surprises are mostly cosmetic, the front bar is stuffed, the side skirts are not original and the paint is peeling off, the rear passenger quarter is full of bog over the wheel arch that I found due to some damage I made and apparently under the rear bumper on that side is not too flash either.
It's also developed the usual knocks in the rear end recently that I'm trying to chase down. It would benefit from some love and care but it would never be worth doing it in a financial sense. See what happens i guess.
Thanks all.
Old 10-06-2015, 12:32 PM   #8
jpblue1000
jpblue1000's Avatar
Thanks all.
Don't judge financial sense too quickly. I picked up an AU repairable write off many years ago, extensive cosmetic damage mostly with a lower a pillar repair necessary. Car was only a few years old and I paid about 25 percent the price of a 'good' one. I spent about half the price of a 'good' one repairing it and VIV process, roof panel, rear 1/4, doors, front 1/4, 'A' post, section of sill, paint, wheels, headlight and threw in a few nice bits then a body straightness report, restraint system report (even though airbags didnt go off as it was parked unattended when it was hit) and engineers report meaning mine had cost me about 3/4 retail and was now a pretty good car, not as same as factory but as different as the next one off the production line, except mine has no rust nor leaks from the heater plenum
I have done +/- 250,000km's in it with no additional problems and the good one is now worth about 3K, mine is probably worth 2K. So have I lost 10K or 1K or gained 2K?
If you do it to sell its harder to not loose money, do it to keep and the financials are easier to balance, oh and shortest Ive ever owned a car is 6 years...damn VW's
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2015, 01:10 PM   #9
dom_105
JP
Undoubtedly. And it's worth to me today is much more then I could get for it anyway.
Old 14-06-2015, 11:30 AM   #10
Morexbs
Morexbs's Avatar
Incorrect.Once it's on the WOVR,it's on there for good.
The VIV is only needed for the initial repair of whatever caused it to be written off and the NEVDIS status gets changed to "Inspected" after that.
He who dies with the most toys is still dead
Morexbs is offline   Reply With Quote Multi-Quote with this Post
