Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 26-02-2015, 10:21 PM   #1
twr7cx
Member
twr7cx's Avatar
Question Shock works front coilovers - how high can they be set?
I have the Shockworks front coilovers in my AU ute. Can you advise how high I can adjust them? From what I recall there is a small hole in the body of the shock - is this about the limit to how far they can be wound out?
The rear of my ute is approximately 12mm above standard XR height as I have heavier duty leaf springs for load carrying. I would like to raise the front to suit.
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2015, 10:36 AM   #2
Shockworks
Default Re: Shock works front coilovers - how high can they be set?
Hi TWR<
Sorry for the late reply as I somehow missed this post.
You will be able to raise the car no problem 12 mm higher than standard and probably quite a bit more. The hole is the indicator to show the limit of the how far you can raise mate.
Brett
Shockworks is offline   Reply With Quote Multi-Quote with this Post
