Ford screwed the Falcon
The first rays of light for 2015 had not yet appeared and I copped a puncture on the way home.
It was only approximately a 4km trip. Started on a gravel road, then when I got on tar I hear a 'tick tick tick' noise from the right rear. Thinking it was a stone stuck in the thread I kept driving with the thought it would eventually dislodge itself. Most of the trip was in 60 and 50 km/hr zones with one short stretch in an 80 zone. Was about 500 metres from home when the back end of the car started vibrating. Back off and crawled it into the driveway. Yup, flat tyre. Have since removed the flat (which has a nice screw in it) and put on the space saver spare. First drive after putting on the spare and get warning messages about ABS and DSC not working. WTF!?!?!? Just because of a flat tyre? Did the vibration dislodge something? I have no idea.
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
If the spare is a different size (rolling diameter) the abs and dsc wont work.
3 users like this post: |
#3 | |||
Thailand Specials
I'm pretty sure space savers are supposed to be the same or close to rolling diameter as the wheels they're designed to replace as a spare though, correct? |
I am using the space saver which was supplied with the car when purchased brand new. You would think the Ford engineers specified a spare tyre which would be compatible.
BTW - the codes are logged as soon as I turn on the car. The wheels have not yet moved so it could not be due to different rolling diameters.
Thailand Specials
Check wheel speed sensor wires/connector for damage, I snapped mine off on a speed hump after the car was lowered.
The space saver in my Fiesta is 1" smaller than normal tyres on the car. Don't know how that works ???
But my i20 has a full size spare...no space saver or can of goo!!!
CSGhia |
Thailand Specials
Two turning.. two burning
No, It would have picked the difference in rolling diameter of the previously flat tire...
You just didn't notice with all the other vibrations and trying to get to your driveway?!
I LIKE BLOWERS, TURBO'S.. AND ENGINES BIG ENOUGH NOT TO NEED EITHER ![]() BLOWN, 2013 FPV GS UTE TURBO TERRITORY GHIA 545ci XB GS UTE Daily, 2006 F250 crew cab BA2 Fairmont Ghia |
#9 | |||
![]() Join Date: Dec 2006
Take it for a short run with the space saver on. It may correct itself.
Oooh baby living in Miami....
#10 | |||
IWCMOGTVM Club Supporter
Daniel |
We had a Kia Cerato that the DSC light was coming on due to the back tyres being about 80% worn and new tyres on the front.
I hope you are correct.
#13 | ||
![]() Join Date: Jan 2005
Is your space saver at the right pressure? They need to be at 60PSI.
My car threw up a ABS/DSC/Check Engine error for having the rears at 50PSI instead of 41 as per recommended.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
#14 | ||
I saw it says on the space saver to inflate it to 60psi but that seems absurdly high.
#15 | |||
PSI is pounds per square inch. Reduce the area, you need to increase the pressure. Same reason a bicycle tyre is inflated to 110 PSI cause it's area is so small. Set the right pressure and the light show should end.
#16 | ||
Come on syndrome... Was I right?
I can't sleep at night not knowing what made your abs light come on ![]()
#17 | ||
Still TBA. Will keep you posted.
#18 | ||
Trev
Driving on a flat tyre can also ruin wheel bearings and also ruin your shock absorber on that side.
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
#19 | ||
Interesting. Put the patched tyre back on the car yesterday. Keyed-on and no warning lights or buzzers before the wheels had even moved and no further warning lights or buzzers after I started to drive the car. I was of the understanding that the system did a self-check once one started driving the car, not while it was stationary.
#20 | ||
I'm thinking if putting the 'proper' wheel back on cleared it then your car was probably just throwing a "get this pox looking wheel off me" code.
#21 | ||
KITTY Crew Member
How would different wheel diameter mess with abs/speed sensor? They read off the tone wheel,not the outside of wheel
FOR SALE BAII Super Pursuit 0083 ![]() Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block Awesome exhaust by THE EXHAUST CENTRE MIDLAND Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments Now with full DOT approval and Permitted for road use
#22 | ||
#23 | ||
Did you set the pressure of the spare to 60 PSI?
#24 | ||
As I said in my previous posts, the warnings started before the wheel have even started to turn and cleared before the wheel started to turn.
#25 | |||
My post was only explaining how/why the car would detect different wheel speeds. |
