Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
Next up?
Hello all,
It seems that when I try to click on this thread Show us your BA/BF!! in the Show' N Shine section, I keep getting this HTTP 500 error (I even get the error when I try to click on some other threads too). I've tried clearing my cache and refreshing the page but with no luck, if anyone could get this sorted for me it'd be greatly appreciated. To be further assisted I am using IE11, but have also tried using Google Chrome to no avail.
If it ain't a Ford you're bored. Blue blooded to the core. ![]() Last edited by WHYME; 08-12-2014 at 07:48 PM. |
Former BTIKD
![]() Join Date: Mar 2005
Works fine here.
Opera 12.17 and Opera 26.0 (Win 8)
Next upgraded Mk1 Leopard
Me to IE 9, firefox 33.1 and chrome
UK
Next up?
So no one has a solution for me?
If it ain't a Ford you're bored. Blue blooded to the core. ![]() |
Clevo Mafia Inc.
![]() Join Date: Dec 2004
First port of call is usually to run CCleaner and clear your cache/temporary files and registry cleanup. Try again after that.
Must be your end if it's working fine for everyone else. |
Next up?
Yep, it's definitely on my end. I just wanted to know if there was an easy fix, thanks for the help and hopefully this works.
Chairman & Administrator
Failing that check whether you are using a proxy server as these can introduce that type of error.
Cheers Russ
Observatio Facta Rotae
Try going to the page you were getting the error message on, and hitting Ctrl+F5. This will force your browser to reload the page from scratch, instead of recalling the error page out of its own memory. If Ctrl+F5 doesn't work, try going into your browser options and clearing your cache there as Falcon Coupe said.
