Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > XR6 & XR8 Club of Queensland
Old 17-10-2014, 09:34 PM   #1
DVK443
Default 09 FG XR6 5sp auto stuck in Drive position.
Hi guys, need some advice on an issue with my car, 09 Fg falcon xr6 5sp auto. Wife just called me to say our car is stuck in drive won't start to allow her to put it in park, she had just parked in the car in our driveway but turned the car off before putting it in park, driveway is on a hill and car has the hand brake on. any idea's please, (apart from don't let the wife drive lol).
Cheers.
DVK443 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2014, 09:14 AM   #2
JC
JC's Avatar
Default Re: 09 FG XR6 5sp auto stuck in Drive position.
It sounds like the mechanism could be faulty - to change from P to anything is a mechanical operation (ie linkage must move, either solid or cable).
I have the same 5R55 gearbox in our explorer, and it requires the footbrake to be on before it will move from Park - is the falcon the same?
Ford Performance Club ACT
Old 18-10-2014, 05:49 PM   #3
STINKY NINJA
Maybe it needs to be pushed forward a wee bit if possible so drive can be disengaged.
Could have rolled back slightly making it hard to get out of drive.
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2014, 09:10 PM   #4
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
It should be going click click through the gears, if not linkage is broken.
Usually you can reattach with wire/cable ties etc as a temp fix.
Many people just drill a hole and bolt the linkage to the arm.
Car wont start in D so need to jack up and fix or manually move selector on side of box if you want to drive it to mechanic etc.
No foot on brake stuff with Falcon.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2014, 09:29 PM   #5
DVK443
Thanks for the replies guys, As Stinky say's I think it needs to be pushed forward slightly to release the pressure on the selector, (wife drove into driveway left it in drive turned the engine off released foot brake then applied the handbrake,) but as its facing uphill on the driveway, I'll need a push from the neighbours, but I'll certainly be looking at all the advice below.
Thanks guys i'll let you know how it goes. cheers.
Old 18-10-2014, 10:53 PM   #6
tut0r
tut0r's Avatar
try getting it into neutral at least as you can start it from there too.
Ride
2007 Ripcurl BF Xr6 Ute
Mods to Date
Ceramic Coated Pacemaker 4495s
2.5" Dual Venom exhaust,
Bluepower CAI
Eaton True Trac with 3.9s
20% Underdrive
EcoLpi Motor
RWKW: 200.0
Nm: 394
Mods to Follow
Supercharger
T56 Conversion TR6060
tut0r is offline   Reply With Quote Multi-Quote with this Post
