Old 08-08-2014, 12:28 PM   #1
Jimbo01
Default Cylinder Head Part No:
Hi guy's,
I have a mate that has a GD Telstar that was overheating, but before I could diagnose what the problem was he'd already taken the cylinder head off it!
He said he spent 2 weeks trying to work out the problem and decided that it was the cylinder head gasket but unfortunatly he'd already pulled it apart before I could test it properly for things like hydrocarbons and compression test it.
Now for the funky part:
He reckons the cylinder head doesn't match up with the engine because the water jackets that go between the engine and the cylinder head don't match up...
Now, the way I was thinking of going about this was giving ford the VIN number for the car, then working out what the part number for the cylinder head is, then try and match that up with what's documented on ford's computers, but I can't find a ford like part number on the cylinder head...
Now when I say "ford like part number" I'm mainly knowledgeable with falcons and most of their part numbers start with DA and such and are about 10-15 characters long or so.....
It's a 2.2l motor (or at least that's what it says on the side of the car!), I'm happy to take some photos to confirm this.
The only markings that stand out is "F201 4-2" on the side of the head and there's another number written on the back of the head (opposite side of the timing gear) but I can't remember what it is.
Cheer's guys!
James
Jimbo01 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2014, 04:42 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: Cylinder Head Part No:
Is this the 2.2 motor with 12 valves in the head
if possible pictures please .. lets see the block then that head fitted
wrong head fitted ....by what is described .. or the wrong block ..anyone,s guess
might be better tossing in a second hand motor if the whole lot has overheated
1987–1992
GD 626 is a mazda identification == AT, AV is Ford Telstar
http://www.ebay.com.au/itm/Mazda-For...1bcddc4&_uhb=1
but it is a mazda engine fitted with ford rocker cover
so either mazda wrecker or ford .you may have to go outside your state to source a head
cant buy the heads new..
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2014, 08:41 PM   #3
Jimbo01
1987–1992
Hi dude,
Yes this is the 2.2l motor.
Pictures for the head are possible but aern't needed, the picture of the head you attached is exactly what the head looks like, so it is now just a case of testing it to see if it's cracked.
If the head is screwed then the fact that it's a Mazda engine also helps a LOT, along with the rest of the info you have given.
Thank you HEAPS!!!!
James
Old 21-09-2014, 04:03 PM   #4
dirty hands
Over Thinker
oh good i kept the image
