#121 | ||
I miss my wheelbarrow
![]() Join Date: Jan 2005
I dont believe the emissions cost would have been much at all... you could tune for stoich and Ethanol would burn cleaner BEFORE you added any timing I promise you.
Plus they run an optical sensor in the return line to manage the injector duty cycle at various % of Ethanol in the tank... Holden would have an easier time doing the calibration on an AFM/E85 badged car than your local SCT tuner would as he has to tune to whats in the tank on the day, Holden have a sensor telling the ECM how much Ethanol is in there. Look at all the aftermarket companies selling Flex Fuel add-on kits out there.. doing it with next to no budget! Daniel |
#122 | ||
#123 | |||
Peter Car
Aftermarket stuff doesn't need that so can be done cheap. |
#124 | ||
#125 | |||
#126 | ||
there was articals in trade papers and local newspapers that certain group of industry requested that the Australian emission measurement standard be modified to bring it inline with other countries.
IE the cold start up process not be measured. that the articals claime was the way it occurs in the USA and Europe for ethonal engines. some if not all emission testing for the direct injection holden engine was done at orbital and was online to read. Its a trade thing lots of big words and graphs. good read. At the time I though thank #### great someone with brains. THEN others complained about certain industries being given a leg up and due to ethonal used in Australia causes starvation in mexico,and that local wood fuel was killing tree frogs---over the other quality hybid and LPG vehicle that was made in OZ-- that's now no longer going to be produced. P/S--when I imported skyline to OZ, the emission test carried out to gain data in NSW and comply it--the test didn't start till the engine was warm--the educated people at the EPA and RTA thought it was stupid to measure this. My 1985 skyline with 165 000KM passed for a new 2002 model car.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA- Land Rover 88 .MIDCOAST NSW.
#127 | |||
If a car had 30lb per hour injectors in it and you swapped in 42lb units (very simple example, but lets assume it was 35% more flow in every way) and swapped to E85 the car would run exactly the same just burn cleaner and have better emissions.... its a very straightforward process very different to say tuning on LPG or LPi Daniel |
3 users like this post: |
#128 | ||
Unsafe @ any Speed
EBII Fairmont 4.0L NA - 206rwkw E85 cocktail === 13.48@102mph Thread here http://www.fordforums.com.au/showthread.php?t=11334087 By HEINRICH PERFORMANCE & TUNING E Series Falcon Image Museum on FB https://www.facebook.com/pages/E-Ser...29864000453208 |
5 users like this post: |
#129 | |||
Old but happy
Bob
2011 Sunburst NA/ZF, Goodyear Eagle F1 Asymmetrical 2, KPM CAI. Heat exchanger removed. ULX110 oil. Detailed by Matthew Gibb, Detailology, tuned by Heinrich Performance. |
#130 | ||
I'm sure the supplied E100 petrol is of a good quality just like a typical 98 octane petrol is, however my worry is the petrol station itself ... Basically that station only serves taxis and I have never seen a single decent car ever pullover to fill up in there. This means that the usage of E100 would be extremely minimal leading to the petrol siting for ages in the tanks, aging, collecting water, and evaporating ... I think this is the reason why I noticed a difference straight away.
BTW I live next to the city, and all the other major petrol stations have a huge turnover ... probably leading to fresh petrol being frequently delivered.
2012 FG MkII XR6 Turbo LE: Winter White + Tint ![]() |
#131 | ||
Was once XR6Turbo81
Gd news from my end as another e85 pump will now be avail to my beast. Closest pump around 5km and the other two within 10kms.
Have been running this fuel for nearly 4 years now without fail! Power gains are excellent, cheap to filll but but but bloody no good for economy if used as a daily. Hmmmm, ponders for a second tune on 98!?! |
#132 | |||
#133 | ||
I totalled my XR6
Accidentally put e10 in my VS Commodore once, ran like poo and got terrible economy.
A mate puts e10 and e85 in his VE Calais, have driven it on both ethanol and ULP and definitely goes better on ethanol - especially e85. It's all about what your car is designed to run on. Let's not rehash the topic of LPG, it has it's place and is a good way to save serious $$$ if you do a lot of kms.
#134 | ||
Member
Absolutely. But it's all relative, a few million in the auto industry is a very small amount. Consider that the EcoBoost project alone cost more than $40 million. I would be surprised if Holden spent even a tenth of that on their E85 project. Then there's EcoPLI, which also would have cost a huge amount of money. From what I've read in a Ford press release, the diesel Territory, EcoLPI and EcoBoost cost a whopping $232 million. Some of it was contributed by the government (which seems to only be fashionable when Ford receives it, I bet if Holden were the ones spending government money on failed projects like EcoBoost, many people around here would be burning them alive for it). So yes, compared to what Ford did (and what some have suggested Holden should have done), the E85 project really did cost Holden next to nothing.
#136 | |||
And probably the same goese for the EcoLPi Falcon too really? Poor advertsisng, lack of of proper knowledge about the industry and system so consumer just goes back to the same old petrol/diesel models they have been buying for aloooong time now??? ![]() Ford and Holdens fault for not marketing products properly really! |
#137 | ||
Member
Still early days for ethanol, we'll see where it goes over the next decade.
#138 | |||
Did you need any hardware (injector, fuel pump etc) or did you get just a tune ? Who did you use ? Also, if 98,100 or e85 isn't available does it run ok on 91 ? Cheers Graham Luckily I've just got a brand new united servo next door to my work. E85 and 100 ![]() |
#139 | ||
Old but happy
I have my car tuned for BP98 for quite some time. It is an NA FG so no hardware changes were required. My car has never used anything less than 98 RON. To run it on 91 RON I presume I would need to retune the tune to stock. Keep in mind I only use 100 RON now,not E85 but could run 98 with no trouble. E85 is a different beast and cannot be used without modifications to your car.
2011 Sunburst NA/ZF, Goodyear Eagle F1 Asymmetrical 2, KPM CAI. Heat exchanger removed. ULX110 oil. Detailed by Matthew Gibb, Detailology, tuned by Heinrich Performance. Last edited by AU1XLS; 12-01-2014 at 09:58 AM. Reason: Topic is E85 not tuners |
#140 | |||
Previous posts have suggested Holden spent ALOT to do it. Maybe Ford preferred to sit back and wait and see how popular the fuel becomes first before spending big money??? That's why I see the EcoLPi as a better move because the fuel is cheap and thers already plenty of pumps around. I really thought the taxi industry would be all over the EcoLPi but some say taxi's are actually never bought new they're usually just ex fleet cars with duel fuel systems I think??? |
#141 | |||
The only thing I wonder is what would have happened if Ford had just gone with the V6 diesel for Falcon, Territory and Ute.. No doubt the fear with that was that diesel option would simply replace I-6 sales without adding volume. But in the great hindsight, a super efficient range of diesel products may have changed Falcon and territory's fortunes. I could imagine that 7 to 8 litres/100 km combined for a large car/Ute/SUV combo would be very attractive to fleet and retail buyers.. Last edited by jpd80; 12-01-2014 at 01:52 PM. |
#142 | |||
The Terri Diesel V6 is built buy Jaguar isn't and obviously already assembled when they get here. |
#143 | |||
Experienced Member
In reality they are making sales & money from it so that in it self tells you E85 progressing forwards not backwards. You can argue much as you like but availability to the public proves it to be a going concern..... FACT! |
#144 | |||
Less people building the same amount of cars, all engine sourced from overseas engine plants... |
#145 | ||
![]() Join Date: Dec 2004
Starting to go around in circles and straying of topic
Closed |
