18-02-2012, 07:29 PM | #1 | ||
http://www.greendieselcorp.com/index.html
This group claims to have converted an alloytec motor to run on diesel? Is this possible? Click 'next' 3 times on the webpage to see the details. |
18-02-2012, 07:36 PM | #2 | ||
Young Ford Enthusiast
would like to see this work in person,
could be a good idea, though you would want to be licenced as it could go bad if people try to convert at home
Ol Reliable: 2004 Ba Sr MkI The Fun Machine: 2007 Bf XR6 Ute MkII |
18-02-2012, 07:43 PM | #3 | ||
Falcon i6 with cast-iron block would run pretty nicely? XR6T diesel?
18-02-2012, 07:46 PM | #4 | |||
Fast car with efficient engine, always a winner.
18-02-2012, 08:05 PM | #5 | ||
Heard of them several years ago and even enquired about converting the Falcon to Diesel but they werent at that stage yet.
18-02-2012, 08:30 PM | #6 | ||
Wasn't the Oldsmobile 350V8 petrol engine converted to diesel at the factory .. Ie. It's the same basic engine converted? (could be wrong) ..
BTW: I think the Olds diesel wasn't much to write home about .. :( |
18-02-2012, 08:34 PM | #7 | ||
SY TS AWD LPG TEZZA
Don't you need more rings on the piston with diesel. I don't think a petrol motor would handle the forces involved. Diesels are beefier from the get go.
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
18-02-2012, 09:07 PM | #8 | |||
Getahaircutandgetarealjob
Te pilos recidene volo et opus solidus capere : |
18-02-2012, 10:53 PM | #9 | ||
If an ultra high pressure injector was the answer to NOX Emission problems, OEMs would be all over it.
18-02-2012, 11:19 PM | #10 | |||
another hairy armpit greeny save the planet bs mob..... |
19-02-2012, 12:57 AM | #11 | ||
who in there right mind would actually convert there car to diesel when there is already cheaper safer and easier option lpg.
19-02-2012, 07:18 AM | #12 | ||
The world still hasn't learnt its lesson that petrol engines converted to diesel just don't work?
19-02-2012, 08:31 AM | #13 | ||
I'm sorry but the block architecture of a lightweight alloy petrol engine isn't strong enough
to support the heavier rotating mass and bigger bearings of Turbo diesel engine. And forget about small NA diesels today, they just don't cut it against modern DI petrol engines... The problem with NOX Emissions comes from efficient combustion of small amounts of fuel, the trick is to increase density of charge without spiking compression pressure and temperature. |
19-02-2012, 10:07 AM | #14 | |||
Purveyor of filth
An allow block engine is not up to the task of running diesel, period. However, a Falcon I6 with beefier conrods, pistons to suit and an iron head, it could be an oil burner.... |
19-02-2012, 10:26 AM | #15 | |||
19-02-2012, 10:28 AM | #16 | |||
http://en.wikipedia.org/wiki/Mitsubishi_4N1_engine |
19-02-2012, 10:30 AM | #17 | ||
wheres mythbusters when you need them
19-02-2012, 11:27 AM | #18 | |||
Purveyor of filth
19-02-2012, 11:31 AM | #19 | ||
Performance moderator
Modern computerised diesels don't bang and thump like the old
mechanical injected motors.. In the past there has been some failures like the 350G.M to diesel etc The motor in the old Mk4 Zephyr was designed as a diesel on the drawing board.. Same motor that was in 3ltr Capri's.. The new diesel motors have heaps of refinement behind them and pass all sorts of EPA.. I doubt converting will be legal ???
19-02-2012, 09:49 PM | #20 | |||
Peter Car
20-02-2012, 12:52 AM | #21 | ||
I read somewhere in the new Terri stuff before it was released that Ford had got the I6 to run on diesel but the program got cut
20-02-2012, 07:48 AM | #22 | |||
cost and the availability of the 2.7 V6 diesel were the reason it wasn't pursued. |
20-02-2012, 08:18 AM | #23 | ||
When Japanese high speed diesels first started to become popular in the late 70's & early 80's the same morons who rubished Range Rovers also rubished Perkins , Gardener Denver , Lister and Petter engines . If a diesel is designed and built correctly it will last forever .
Chevy badges , the Polariser of the new millenia . |
20-02-2012, 08:56 AM | #24 | |||
20-02-2012, 10:41 PM | #25 | ||
Peter Car
Yeah, I remember hearing that. And the Skyactive petrol compression was up to around 14:1, which is sky high for a petrol, they obviously came up with some sort of trick way to keep detonation under control.
Extremely unusual for a petrol engine to nearly match an alternate diesel's compression. |
