Treasure your balls?
As the title says...
Key will turn ¼ turn but nothing happens. Thanks, Rob
Meteorite T3 TS50 ESS |
![]() Join Date: Jan 2005
WD40 in the lock, let it soak then try again?
roof racks? geez Rob what'll it be next? lpg??
Anyhow ... are you installing or removing? I don't understand when you say "nothing happens". After turning the key to unlock the cover you then have to pull the cover away from the mounting bracket so you can get to the release lever. The cover slides towards you in a horizontal movement to come away from the bracket. |
Haha Jeff, that's why I posted here and not the usual location. Okay, just got home and will try it, thanks.
Okay, pretty straight forward once you understand the concept. Yesterday I was trying to pull the whole cover, let alone trying to stand, not just the top one by itself...
![]() . . . . . So what's needed for the LPG install Jeff. ![]() . . . .
Meteorite T3 TS50 ESS Last edited by Hords; 18-08-2010 at 04:11 PM. |
Flairs - Truckers Delight
Cool man
glad to hear you got it sorted we used to have roof racks on the cabs to put the hail light etc on i'd completely forgotten how to pull them on and off
2006-2016: Regency Red 2000 AUII Ford Falcon Forte Automatic Sedan Tickford LPG "Millennium Falcon" Last edited by Mr Hardware; 18-08-2010 at 05:53 PM. |
#7 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
![]() Now off ya go again ![]() Thanks for the picky to mate I had visions of the T with a pack rack stuck on it ![]()
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
while we`re going , how much weight can you put on these?
80 kilos
thats pretty good, thanks.
Hi there
When I put factory roof racks onto my AUII sedan, I get a "no confidence" feeling They seem to only hold on to the thin metal seam around the doors. When I close the clamp down, they seem however to be rock solid. Can someone maybe give me the heads up on the physics at work here, do the clamps somehow put downward pressure on, and if so it still seems the thin metal seam is the only thing stopping them being pulled up and off. And how does the ajustable nut on them come into play. Maybe I'm just a worry wart..? Any comments would be appreciated cheers guys! |
Anyone? please
