Old 09-12-2011, 12:26 AM   #1
63futura
63futura's Avatar
Default Tailshaft loop position
I'm fitting a tailshaft loop and was told it needed to be 6inches from uni joint but my H pipe is exactly 6inches from my front uni ! Should I put it infront of the H pipe or behind ?
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2011, 12:36 AM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
Default Re: Tailshaft loop position
Depends where H pipe is..
The loop should be no further back than 6" from uni...
Or you'll have clearance issues..
Daily driver GTE FG..
Old 09-12-2011, 12:45 AM   #3
63futura
63futura's Avatar
If I put it infront of the H pipe it's about 4inches from uni
Will that be fine for drag racing ?
Old 09-12-2011, 09:36 PM   #4
JG33RD
JG33RD's Avatar
Yes. Has to be within a max of 6" from front uni, so 4" should be no drama.
JG33RD is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2011, 03:02 PM   #5
63futura
63futura's Avatar
Thats what i thought
Thanks for that
Old 10-12-2011, 11:12 PM   #6
perthfggsute
yep i had a similar issue on a xe i built up,i actually made my own safety loop,and mine was 3.5 to 4 inches behind the front uni joint,i guess its just so with suspension movement its still inside the loop,if it ever broke (heaven forbid,as that would be a wild ride with all the noise etc!),so i think you are all set,good to see you are looking at this as a lot of people overlook it,but imagine a tailshaft letting go at the front without the loop in place,blokes have died even in the street class 11.00 second bracket.well done mate.
cheers dave perth
december 2010 fg gs 315 ute
Tuned by Monsta Torque
395.2 KW
610 NM
3.07 diff ratio (changed from original 3.73)
6 spot brembo's on the front
3 inch manta cat back exhaust with X piece
6 speed manual
k & n air filter
rear calipers painted red
debadged stripes etc removed
perthfggsute is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2011, 03:36 AM   #7
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
After my last carnage.....I'll be fitting a loop on the rear too. That thing can flail around pretty bad.
http://www.youtube.com/watch?v=gfGMaWh4B9A
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2011, 02:16 PM   #8
perthfggsute
thats pretty wild!,good you got it all on film though,better than the front letting go,if the front lets go and it digs in,well the car can do real well in the pole vault section of the olympics,and the driver gets to go along for the ride,not good
395.2 KW
610 NM
6 speed manual
k & n air filter
