Old 18-11-2011, 08:17 PM   #1
amievil
Default Dash Trouble. HELP
Hi all
I was driving along today when all of the gauges and warning lights turned themselves off.
I didn't notice any warning lights before hand.
Then they intermittently came back on but turned back off straight away.
Any ideas?
Thanks
Brad
amievil is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2011, 09:15 PM   #2
Ford Falcon XR6
Ford Falcon XR6's Avatar
Default Re: Dash Trouble. HELP
Hi mate welcome to the forums. Sounds to me like you may have a bad earth or loose connection i'd check the back of the cluster and see if any of the plugs are loose.
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2011, 12:35 PM   #3
amievil
Hi
Thanks for that.
I don't think that that will be the problem as I had the dash out a few months ago.
I'll have a look at it if it stops raining in Melbourne.
My father thought it may been a problem with the cars CPU.
The only other thing I can think of is that the battery may be dying or, I had the battery disconnected last weekend to have a new exhaust tip welded on. Maybe I knocked something or haven't reconnected tight enough.
I only disconnected the positive site of the battery when welding.
Could this have caused a problem?
Thanks
Brad
Old 20-11-2011, 01:05 AM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Sounds like a bad earth. Worth checking the alternator and re-checking the battery terminals, though; very low voltage will do that too. Welding won't have done any damage, so you can breathe easy there
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2011, 08:32 PM   #5
amievil
Hi guy's.
I went out to have a look at the car yesterday and the battery was dead flat.
So I put it on charge last night, got up this morning, and it's still dead.
Looks like the battery has died and gone to battery heaven. Time to get a new one.
I must have been lucky to get it started Friday to get home!
Thanks for all of your help.
Brad
Old 21-11-2011, 10:32 PM   #6
amievil
Hi all
Just an update.
Went an got a new battery, put it in, started the car, battery light still on and gauges still doing funny things.
So I go and have a look under the bonnet. Something doesn't smell right.
So I start checking things. Get the multimeter out and hook it up to the battery and start the car again. The reading goes straight up to 17+ volts!
Quickly shut the engine off.
The regulator in the alternator must have died, and it's pumped out too much power and fried the old battery.
Hopefully I found the problem before it's done any major damage.
New alternator in and running fine.
A bit of an expensive day!!
Thanks
Brad
