09-03-2011, 11:04 PM | #1 | ||
All Bran = Regular Member
I replaced all (4) front ball joints today (boy! did that make a difference to the front end...)
I was lucky enough to borrow a mini-press from a guy who comes through work, so for those who haven't seen one (as I hadn't) here's a pic of it in action on upper and lower ball joints. Took about 30 minutes to remove and install per ball joint (that's with wheel, disc and caliper removed), although a few minutes per bjt was spent working out which adapters to use:- |
10-03-2011, 10:00 AM | #2 | ||
Very impressive, do you know how much one of these is worth?
10-03-2011, 12:54 PM | #3 | ||
He said "a couple of hundred bucks".
Pic of the box for anyone who wishes to chase one up |
10-03-2011, 01:56 PM | #4 | ||
Walking with God
Nice bit of kit.
Most people just buy the whole hub and do it that way. In any case, glad the front end is better. GK
10-03-2011, 02:00 PM | #5 | ||
Just another mock-up..
Mate, that's awesome...
I need to find someone down here with one.. My balljoints are due for replacement..!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
10-03-2011, 06:48 PM | #6 | ||
around 500 to buy
10-03-2011, 06:51 PM | #7 | ||
I like it. Wouldn't be hard to make one. One with a hydraulic bottle jack would be good.
10-03-2011, 06:58 PM | #8 | ||
Flairs - Truckers Delight
Thats pretty awesome ronwest. They should have supplied these with the AUs from new, that would pretty much cancel out my entire list of irritations with AUs.
10-03-2011, 08:17 PM | #9 | ||
Also very handy when doing rear suspension bushes in BA's etc.
AU XLS. |
10-03-2011, 09:13 PM | #10 | ||
Made this for the cost of some welding rods
http://www.fordforums.com.au/showthread.php?t=11324702 They are a must have tool if do your own work. |
10-03-2011, 10:13 PM | #11 | |||
10-03-2011, 10:31 PM | #12 | ||
Not a bad idea either Jastel.
10-04-2011, 06:41 PM | #13 | ||
Sly like a G6
I found this alternative method in the B-series forum.
http://www.fordforums.com.au/showpos...45&postcount=7 If it works for me too, it'll be between $450 and $680 less than the quotes I've had for the GGT-400 Ron used. No disrespect Ron, your post (and the other replies) got me thinking there had to be something affordable out there for those of us without Jastel's fabbing and welding skills. I wouldn't mind trying to adapt the steering wheel puller that paid for itself the one time I needed it & has been gathering dust ever since... My wife's AU3 has been groaning over bumps & low-speed steering just like my AU1 did when it had a seized ball joint, and just today a new noise started, which I've tracked down to a shat left-front wheel bearing. If I have to pull enough bits off to replace a hub/bearing assy, I might as well go a bit further and do the ball joints on that side if I can do it all in situ. And while I've got the front end up on stands, I might as well do the other side too. It's up to 170,000km or so, so worth doing now & hopefully I won't have to worry about them again in the 6-7 years we'll probably keep the car.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
12-04-2011, 09:41 PM | #14 | ||
Fantastic Plastic
yo can make yourself a small mini press out of an old small hydraulic car jack, pretty easily too ! , cheers.
12-04-2011, 09:51 PM | #15 | |||
12-04-2011, 11:04 PM | #16 | |||
12-04-2011, 11:30 PM | #17 | ||
Sly like a G6
Yeah that's always a risk. The B-series one worked fine for the poster, but there's also a post from someone who needed a 30-tonne press IIRC to get their lowers out. Worth trying IMHO and only my time lost if it fails.
30-07-2011, 12:00 AM | #18 | |||
Hi peoples i paid $375 for mine i had to order it from auto Barn place they hadn't heard of it till i asked for one. considering it cost me $350 at pedders to change 2 upper rear control arm bushes it shouldn't take long to pay for itself. 4350 |
