I know this is the wrong forum and place to ask this, but my mate wants to lower his VR Calais, he said someone suggested him "lowering blocks". I thought lowering blocks are only used on cars with leaf spring suspension (which I think a VR Calais doesn't have?).
Thanks much. |
Slow Sunday driver
hahahahahahahahaha
the big press at sims metal should lower it nicely !
sorry dude some one had to say it spend the money to do it properly buy new springs last longer and handle better |
FGX XR8
As mildxe said spend the money and do it properly, Will be a much better car having done it properly.
Formally kotevski22
Just tell him it can't be done,go buy a ford.
I'm going to suggest lowering springs, but once you do that you generally have to replace the shock absorbers too right?
Doyou have to match them up or would any new shock absorber do with the new springs? Thanks much guys. Also I agree, put it in the press. |
The only thing u'll see!!
Same consept as falcon. It has coils all round. However watch the back, as lowering will induce excessive camber, so rear camber kits will be required.
My car has launch control, simply BAM-BAM-BAM-BAM-BAM-BAM-BAM then select D for maximum respect, it bushfires the s**t house everytime!!! |
FORMERLY TX3DUDE
It helps to match the shocks with the springs yes. I suggest your friend visits your local suspension shop. Lowering springs are the way to go. VR is notorious for bad camber on the rear when lowered - it may need other bits to do it "properly"
#9 | |||
5 fat blokes???
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car BA GT-P for the shed Mustang GT for the other half E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it. BA XR6T for a daily NT Pajero for the bush XB 4 door project- swallows a BF xr6 turbo My dad is a generous bloke. He gave away his dead car batteries free of charge.... |
#11 | |||
Cane Farmer
Just chuck some lowered springs in it...I'm sure he'd be happy with that
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
#12 | ||
The BEST Falcon is the AU
Oxy torch
#13 | ||
Falcon RTV - FG G6ET
![]() Join Date: Mar 2007
Let some air out of the tires. Then "it'll just go better."
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
#14 | |||
not here much anymore
I'd also suggest a camber kit as they are notorious to having camber issues when lowered.
RAM 1500
#15 | ||
Clevo Mafia Inc.
![]() Join Date: Dec 2004
If you had put in this in the suspension tech area you may have received the help without the usual comments in between.
